在全志A64平台点亮GC2145
大文实验室出品
2017/5/25 15:13
版本:V1.0
小技巧,直接在全志A64的SDK中搜索ov5640(默认是几乎通的),全部替换为gc2145即可。
rootroot@rootroot-E400:~/wyb$ cd gc2145_bpi_a64_android/
rootroot@rootroot-E400:~/wyb/gc2145_bpi_a64_android$ grep ov5640 . -R
1、
R:\wyb\gc2145_bpi_a64_android\android\device\softwinner\bpi-m64-lcd\configs\camera.cfg
; 用于camera的配置
; 采用格式:
; key = key_value
; 注意: 每个key需要顶格写;
; key_value紧跟着key后面的等号后面, 位于同一行中;
; key_value限制大小为256字节以内;
; exif information of “make” and “model”
key_camera_exif_make = MAKE_A64
key_camera_exif_model = MODEL_A64
; 1 for single camera, 2 for double camera
number_of_camera = 1
; CAMERA_FACING_BACK
; ov5640 gc2145
camera_id = 0
; 1 for CAMERA_FACING_FRONT
; 0 for CAMERA_FACING_BACK
camera_facing = 0
; 1 for camera without isp(using built-in isp of Axx)
; 0 for camera with isp
use_builtin_isp = 0
; camera orientation (0, 90, 180, 270)
camera_orientation = 180
; driver device name
camera_device = /dev/video0
; device id
; for two camera devices with one CSI
device_id = 0
used_preview_size = 1
key_support_preview_size = 640x480
key_default_preview_size = 640x480
used_picture_size = 1
key_support_picture_size = 1600x1200, 1280x720, 800x600, 640x480
;key_support_picture_size = 1600x1200, 640x480
key_default_picture_size = 640x480
used_flash_mode = 0
key_support_flash_mode = on,off,auto
key_default_flash_mode = on
used_color_effect = 1
key_support_color_effect = none,mono,negative,sepia,aqua
key_default_color_effect = none
used_frame_rate = 1
key_support_frame_rate = 30
key_default_frame_rate = 30
used_focus_mode = 1
key_support_focus_mode = auto,infinity,macro,fixed,continuous-video,continuous-picture
key_default_focus_mode = auto
used_scene_mode = 0
key_support_scene_mode = auto,portrait,landscape,night,night-portrait,theatre,beach,snow,sunset,steadyphoto,fireworks,sports,party,candlelight,barcode
key_default_scene_mode = auto
used_white_balance = 1
key_support_white_balance = auto,incandescent,fluorescent,warm-fluorescent,daylight,cloudy-daylight
key_default_white_balance = auto
used_exposure_compensation = 1
key_max_exposure_compensation = 3
key_min_exposure_compensation = -3
key_step_exposure_compensation = 1
key_default_exposure_compensation = 0
key_horizonal_view_angle = 48.6
key_vertical_view_angle = 37.0
used_zoom = 1
key_zoom_supported = true
key_smooth_zoom_supported = false
key_zoom_ratios = 100,120,150,200,230,250,300
key_max_zoom = 30
key_default_zoom = 0
2、
R:\wyb\gc2145_bpi_a64_android\android\device\softwinner\bpi-m64-lcd\init.sun50iw1p1.rc
# csi module
insmod /system/vendor/modules/videobuf2-core.ko
insmod /system/vendor/modules/videobuf2-memops.ko
insmod /system/vendor/modules/videobuf2-dma-contig.ko
insmod /system/vendor/modules/vfe_io.ko
insmod /system/vendor/modules/actuator.ko
insmod /system/vendor/modules/dw9714_act.ko
#insmod /system/vendor/modules/ov5640.ko
insmod /system/vendor/modules/gc2145.ko
insmod /system/vendor/modules/vfe_v4l2.ko
3、(可选操作:)
R:\wyb\gc2145_bpi_a64_android\android\device\softwinner\bpi-m64-lcd\ueventd.sun50iw1p1.rc
/dev/video0 0770 media media
#/dev/video1 0770 media media
4、
R:\wyb\gc2145_bpi_a64_android\lichee\linux-3.10\arch\arm64\boot\dts\sun50iw1p1.dtsi
csi0:vfe@0 {
device_type= "csi0";
compatible = "allwinner,sunxi-vfe";
interrupts = <GIC_SPI 84 4>;/*SUNXI_IRQ_CSI0 (SUNXI_GIC_START + 84 ) = 116*/
pinctrl-names = "default","sleep";
pinctrl-0 = <&csi0_pins_a>;
pinctrl-1 = <&csi0_pins_b>;
cci_sel = <0>;
csi_sel = <0>;
mipi_sel = <0>;
isp_sel = <0>;
csi0_sensor_list = <0>;
csi0_mck = <&pio PE 1 1 0 1 0>; /*PE1 .mul_sel = 1, .pull = 0, .drv_level = 1, .data = 0*/
status = "okay";
csi0_dev0:dev@0{
csi0_dev0_mname = "ov5640";
修改为:
csi0_dev0_mname = "gc2145";
csi0_dev0_twi_addr = <0x78>;
csi0_dev0_pos = "rear";
csi0_dev0_isp_used = <1>;
csi0_dev0_fmt = <0>;
csi0_dev0_stby_mode = <0>;
csi0_dev0_vflip = <0>;
csi0_dev0_hflip = <0>;
csi0_dev0_iovdd = "iovdd-csi";
csi0_dev0_iovdd_vol = <2800000>;
csi0_dev0_avdd = "avdd-csi";
csi0_dev0_avdd_vol = <2800000>;
csi0_dev0_dvdd = "dvdd-csi-18";
csi0_dev0_dvdd_vol = <1500000>;
csi0_dev0_afvdd = "";
csi0_dev0_afvdd_vol = <>;
csi0_dev0_power_en = <>;
csi0_dev0_reset = <&pio PE 14 1 0 1 0>; /*PE14 .mul_sel = 1, .pull = 0, .drv_level = 1, .data = 0*/
csi0_dev0_pwdn = <&pio PE 15 1 0 1 0>; /*PE15 .mul_sel = 1, .pull = 0, .drv_level = 1, .data = 0*/
csi0_dev0_flash_used = <1>;
csi0_dev0_flash_type = <2>;
csi0_dev0_flash_en = <>;
csi0_dev0_flash_mode = <>;
csi0_dev0_flvdd = "vdd-csi-led";
csi0_dev0_flvdd_vol = <3300000>;
csi0_dev0_af_pwdn = <>;
csi0_dev0_act_used = <0>;
csi0_dev0_act_name = "ad5820_act";
csi0_dev0_act_slave = <0x18>;
status = "okay";
5、
R:\wyb\gc2145_bpi_a64_android\lichee\linux-3.10\drivers\media\platform\sunxi-vfe\device\Makefile
(小技巧,可以除了gc2145之外的全部的摄像头驱动都用#注释掉,以减少编译时间和生成的IMG的体积!)
obj-m += ov5640.o
obj-m += ov2640.o
#obj-m += ov7736.o
#obj-m += s5k4ec.o
#obj-m += s5k4ec_mipi.o
#obj-m += gc2035.o
#obj-m += gt2005.o
#obj-m += gc0307.o
obj-m += gc0308.o
#obj-m += gc0328.o
#obj-m += gc0328c.o
obj-m += gc2145.o
#obj-m += gc0329.o
#obj-m += gc0311.o
#obj-m += hi253.o
#obj-m += sp2518.o
#obj-m += sp2519.o
#obj-m += sp0718.o
#obj-m += sp0838.o
#obj-m += ov16825.o
#obj-m += ov5650.o
#obj-m += ov5647.o
#obj-m += ov5647_mipi.o
#obj-m += t8et5.o
#obj-m += s5k4e1.o
#obj-m += s5k4e1_mipi.o
#obj-m += sp2518.o
#obj-m += sp0718.o
#obj-m += gc5004.o
#obj-m += gc5004_mipi.o
#obj-m += ov5648.o
#obj-m += ar0330.o
#obj-m += ov5648.o
#obj-m += sp5408.o
#obj-m += ov12830.o
#obj-m += ov8825.o
#obj-m += ov8850.o
#obj-m += gc2155.o
#obj-m += ov8858.o
#obj-m += ov13850.o
#obj-m += imx214.o
#obj-m += ov8858_4lane.o
#obj-m += sp5409.o
#obj-m += s5k5e2yx.o
#obj-m += ov2710_mipi.o
#obj-m += ov2686.o
6、
R:\wyb\gc2145_bpi_a64_android\lichee\linux-3.10\drivers\media\platform\sunxi-vfe\utility\sensor_info.c
struct sensor_item sensor_list_t] =
// name i2c_addr sensor type sensor size sensor max pclk
{ "ov2640" , 0x60, SENSOR_YUV , PIXEL_NUM_2M , CORE_CLK_RATE_FOR_2M},
{ "ov5640" , 0x78, SENSOR_YUV , PIXEL_NUM_5M , CORE_CLK_RATE_FOR_5M},
{ "ov5647" , 0x6c, SENSOR_RAW , PIXEL_NUM_5M , CORE_CLK_RATE_FOR_5M},
{ "ov5647_mipi" , 0x6c, SENSOR_RAW , PIXEL_NUM_5M , CORE_CLK_RATE_FOR_5M},
{ "ov5650" , 0x50, SENSOR_RAW , PIXEL_NUM_5M , CORE_CLK_RATE_FOR_5M},
{ "ov5648" , 0x6c, SENSOR_RAW , PIXEL_NUM_5M , CORE_CLK_RATE_FOR_5M},
{ "ov8825" , 0x6c, SENSOR_RAW , PIXEL_NUM_8M , CORE_CLK_RATE_FOR_8M},
{ "ov8850" , 0x20, SENSOR_RAW , PIXEL_NUM_8M , CORE_CLK_RATE_FOR_8M},
{ "ov12830" , 0x6c, SENSOR_RAW , PIXEL_NUM_12M , CORE_CLK_RATE_FOR_16M},
{ "ov16825" , 0x6c, SENSOR_RAW , PIXEL_NUM_16M , CORE_CLK_RATE_FOR_16M},
{ "gc0329" , 0x62, SENSOR_YUV , PIXEL_NUM_0_3M , CORE_CLK_RATE_FOR_2M},
{ "gc0309" , 0x42, SENSOR_YUV , PIXEL_NUM_0_3M , CORE_CLK_RATE_FOR_2M},
{ "gc0307" , 0x42, SENSOR_YUV , PIXEL_NUM_0_3M , CORE_CLK_RATE_FOR_2M},
{ "gc0308" , 0x42, SENSOR_YUV , PIXEL_NUM_0_3M , CORE_CLK_RATE_FOR_2M},
{ "gc2035" , 0x78, SENSOR_YUV , PIXEL_NUM_2M , CORE_CLK_RATE_FOR_2M},
{ "gt2005" , 0x78, SENSOR_YUV , PIXEL_NUM_2M , CORE_CLK_RATE_FOR_2M},
{ "gc2015" , 0x60, SENSOR_YUV , PIXEL_NUM_2M , CORE_CLK_RATE_FOR_2M},
{ "gc2235" , 0x78, SENSOR_RAW , PIXEL_NUM_2M , CORE_CLK_RATE_FOR_2M},
{ "sp0838" , 0x30, SENSOR_YUV , PIXEL_NUM_0_3M , CORE_CLK_RATE_FOR_2M},
{ "sp0718" , 0x6c, SENSOR_YUV , PIXEL_NUM_0_3M , CORE_CLK_RATE_FOR_2M},
{ "sp2518" , 0x6c, SENSOR_YUV , PIXEL_NUM_2M , CORE_CLK_RATE_FOR_2M},
{ "hi253" , 0x40, SENSOR_YUV , PIXEL_NUM_2M , CORE_CLK_RATE_FOR_2M},
{ "hi257" , 0x40, SENSOR_YUV , PIXEL_NUM_2M , CORE_CLK_RATE_FOR_2M},
{ "s5k4ec" , 0x5a, SENSOR_YUV , PIXEL_NUM_5M , CORE_CLK_RATE_FOR_5M},
{ "s5k4ec_mipi" , 0x5a, SENSOR_YUV , PIXEL_NUM_5M , CORE_CLK_RATE_FOR_5M},
{ "s5k4e1" , 0x20, SENSOR_RAW , PIXEL_NUM_5M , CORE_CLK_RATE_FOR_5M},
{ "s5k4e1_mipi" , 0x20, SENSOR_RAW , PIXEL_NUM_5M , CORE_CLK_RATE_FOR_5M},
{ "t4k05" , 0x6c, SENSOR_RAW , PIXEL_NUM_8M , CORE_CLK_RATE_FOR_8M},
{ "t8et5" , 0x78, SENSOR_RAW , PIXEL_NUM_5M , CORE_CLK_RATE_FOR_5M},
{ "ar0330" , 0x20, SENSOR_RAW , PIXEL_NUM_3M , CORE_CLK_RATE_FOR_3M},
{ "bf3a03" , 0xDC, SENSOR_YUV , PIXEL_NUM_0_3M , CORE_CLK_RATE_FOR_2M},
{ "gc0311" , 0x66, SENSOR_YUV , PIXEL_NUM_0_3M , CORE_CLK_RATE_FOR_2M},
{ "gc5004" , 0x6c, SENSOR_RAW , PIXEL_NUM_5M , CORE_CLK_RATE_FOR_5M},
{ "gc5004_mipi" , 0x6c, SENSOR_RAW , PIXEL_NUM_5M , CORE_CLK_RATE_FOR_5M},
{ "nt99252" , 0x6c, SENSOR_YUV , PIXEL_NUM_2M , CORE_CLK_RATE_FOR_2M},
{ "ov7736" , 0x42, SENSOR_YUV , PIXEL_NUM_0_3M , CORE_CLK_RATE_FOR_2M},
{ "gc2145" , 0x78, SENSOR_YUV , PIXEL_NUM_2M , CORE_CLK_RATE_FOR_2M},
{ "gc2155" , 0x78, SENSOR_YUV , PIXEL_NUM_2M , CORE_CLK_RATE_FOR_2M},
{ "gc0328c" , 0x42, SENSOR_YUV , PIXEL_NUM_0_3M , CORE_CLK_RATE_FOR_2M},
{ "gc0328" , 0x42, SENSOR_YUV , PIXEL_NUM_0_3M , CORE_CLK_RATE_FOR_2M},
7、
R:\wyb\gc2145_bpi_a64_android\lichee\linux-3.10\drivers\media\platform\sunxi-vfe\config.c
struct ccm_config ccm0_def_cfg] = {
.ccm = "ov5640",
修改为:
.ccm = "gc2145",
.twi_id = 1,
.i2c_addr = 0x78,
.is_isp_used = 0,
.is_bayer_raw = 0,
.vflip = 0,
.hflip = 0,
.iovdd_str = "",
.avdd_str = "",
.dvdd_str = "",
.afvdd_str = "",
.flvdd_str = "",
.power = {
.stby_mode = 1,
.iovdd_vol =2800000, /* voltage of sensor module for interface */
.avdd_vol =2800000, /* voltage of sensor module for analog */
.dvdd_vol =1500000, /* voltage of sensor module for core */
.afvdd_vol =2800000, /* voltage of sensor module for vcm sink */
.flvdd_vol = 3300000,/* voltage of sensor module for flash led */
.gpio = {
[MCLK_PIN] = {.gpio = GPIOE(1)/*129*/, .mul_sel = 1, .pull = 0, .drv_level = 1, .data = 0,},
[RESET] = {GPIOE(14)/*142*/, 1, 0, 1, 0,},
[PWDN] = {GPIOE(15)/*143*/, 1, 0, 1, 0,},
[POWER_EN] = {GPIO_INDEX_INVALID, 0, 0, 0, 0,},
[AF_PWDN] = {GPIO_INDEX_INVALID, 0, 0, 0, 0,},
.flash_used = 0,
.flash_type = 0,
.act_used = 0,
.act_name = "ad5820_act",
.act_slave = 0x18,
8、
R:\wyb\gc2145_bpi_a64_android\lichee\tools\pack\chips\sun50iw1p1\configs\bpi-m64-lcd\sys_config.fex
;csi (COMS Sensor Interface) configuration
;csi(x)_dev(x)_used: 0:disable 1:enable
;csi(x)_dev(x)_isp_used 0:not use isp 1:use isp
;csi(x)_dev(x)_fmt: 0:yuv 1:bayer raw rgb
;csi(x)_dev(x)_stby_mode: 0:not shut down power at standby 1:shut down power at standby
;csi(x)_dev(x)_vflip: flip in vertical direction 0:disable 1:enable
;csi(x)_dev(x)_hflip: flip in horizontal direction 0:disable 1:enable
;csi(x)_dev(x)_iovdd: camera module io power handle string, pmu power supply
;csi(x)_dev(x)_iovdd_vol: camera module io power voltage, pmu power supply
;csi(x)_dev(x)_avdd: camera module analog power handle string, pmu power supply
;csi(x)_dev(x)_avdd_vol: camera module analog power voltage, pmu power supply
;csi(x)_dev(x)_dvdd: camera module core power handle string, pmu power supply
;csi(x)_dev(x)_dvdd_vol: camera module core power voltage, pmu power supply
;csi(x)_dev(x)_afvdd: camera module vcm power handle string, pmu power supply
;csi(x)_dev(x)_afvdd_vol: camera module vcm power voltage, pmu power supply
;fill voltage in uV, e.g. iovdd = 2.8V, csix_iovdd_vol = 2800000
;fill handle string as below:
;axp22_eldo3
;axp22_dldo4
;axp22_eldo2
;fill handle string “” when not using any pmu power supply
[csi0]
csi0_used = 1
csi0_sensor_list = 1
修改为:
csi0_sensor_list = 0
csi0_pck = port:PE00<2>
csi0_mck = port:PE01<0><0><1><0>
修改为:
csi0_mck = port:PE01<2>
csi0_hsync = port:PE02<2>
csi0_vsync = port:PE03<2>
csi0_d0 = port:PE04<2>
csi0_d1 = port:PE05<2>
csi0_d2 = port:PE06<2>
csi0_d3 = port:PE07<2>
csi0_d4 = port:PE08<2>
csi0_d5 = port:PE09<2>
csi0_d6 = port:PE10<2>
csi0_d7 = port:PE11<2>
csi0_sck = port:PE12<2>
csi0_sda = port:PE13<2>
[csi0/csi0_dev0]
csi0_dev0_used = 1
csi0_dev0_mname = “ov5640”
修改为:
csi0_dev0_mname = “gc2145”
csi0_dev0_twi_addr = 0x78
csi0_dev0_pos = “rear”
csi0_dev0_isp_used = 1
csi0_dev0_fmt = 0
csi0_dev0_stby_mode = 0
csi0_dev0_vflip = 1
csi0_dev0_hflip = 1
csi0_dev0_iovdd = “avdd-csi”
csi0_dev0_iovdd_vol = 2800000
csi0_dev0_avdd = “avdd-csi”
csi0_dev0_avdd_vol = 2800000
csi0_dev0_dvdd = “dvdd-csi-18”
csi0_dev0_dvdd_vol = 1500000
csi0_dev0_afvdd = “avdd-csi”
csi0_dev0_afvdd_vol = 2800000
csi0_dev0_reset = port:PE16<0><0><1><0>
csi0_dev0_pwdn = port:PE17<0><0><1><0>
csi0_dev0_flash_used = 0
csi0_dev0_flash_type = 2
csi0_dev0_flvdd = “”
csi0_dev0_af_pwdn =
csi0_dev0_act_used = 1
csi0_dev0_act_name = “dw9714_act”
csi0_dev0_act_slave = 0x18
小缺陷:
本文的方法是可以点亮gc2145,并且可以以VGA分辨率预览,以1600x1200, 1280x720, 800x600, 640x480拍照正常。但是录像出错(480P/720P)。愿意不明。
出错的logcat:
01-01 09:30:51.417 8118 8118 I CAM_VideoModule: startVideoRecording: Thread[main,5,main]
01-01 09:30:51.418 8118 8118 V CAM_VideoUI: mFocusRing.stopFocusAnimations()
01-01 09:30:51.418 3592 23109 W CameraHardware: unknow focus status: -1
01-01 09:30:51.423 8118 12119 D CAM_Storage: External storage state=mounted
01-01 09:30:51.435 8118 8118 I CAM_VideoModule: initializeRecorder: Thread[main,5,main]
01-01 09:30:51.440 3592 6982 W StagefrightRecorder: Max file duration is not positive: 0 us. Disabling duration limit.
01-01 09:30:51.440 3592 6982 W StagefrightRecorder: Target duration (0 us) too short to be respected
01-01 09:30:51.440 8118 8118 D CAM_LcyLocProvider: No location received yet.
01-01 09:30:51.441 8118 8118 D CAM_LcyLocProvider: No location received yet.
01-01 09:30:51.441 8118 8118 V CAM_VideoModule: New video filename: /storage/emulated/0/DCIM/Camera/VID_20100101_093051.mp4.tmp
01-01 09:30:51.449 3592 23109 W CameraHardware: unknow focus status: -1
01-01 09:30:51.452 3592 7016 D awplayer: <get_omx_component_factory_fn:276>: ----get_omx_component_factory_fn
01-01 09:30:51.452 3592 7016 D awplayer: getCallingProcessName:263: Calling process is: com.android.camera2
01-01 09:30:51.452 3592 7016 D awplayer: <omx_venc:353>: omx_enc Create!
01-01 09:30:51.452 3592 7016 D awplayer: <component_init:433>: COMPONENT_INIT, name = OMX.allwinner.video.encoder.avc
01-01 09:30:51.452 3592 7016 E OMXNodeInstance: getParameter(48:allwinner.encoder.avc, ParamVideoProfileLevelQuerySupported(0x600000f)) ERROR: BadParameter(0x80001005)
01-01 09:30:51.452 3592 7016 W ACodec : do not know color format 0x7f000789 = 2130708361
01-01 09:30:51.452 3592 7016 D awplayer: <component_deinit:2055>: component_deinit
01-01 09:30:51.453 3592 23420 D awplayer: ComponentThread:2989: x stop command.
01-01 09:30:51.453 3592 23421 D awplayer: ComponentVencThread:3895: vencThread detect nStopFlag[1], exit!
01-01 09:30:51.454 3592 7016 D awplayer: <check_lib_unload:394>: Unloading the dynamic library for OMX.allwinner.video.encoder.avc
01-01 09:30:51.454 3592 7016 W StagefrightRecorder: Intended video encoding bit rate (8000000 bps) is too large and will be set to (3000000 bps)
01-01 09:30:51.455 3592 7016 E CameraSource: Video dimension (1280x720) is unsupported
01-01 09:30:51.456 8118 8118 E MediaRecorder: start failed: -19
01-01 09:30:51.456 8118 8118 E CAM_VideoModule: Could not start media recorder.
01-01 09:30:51.456 8118 8118 E CAM_VideoModule: java.lang.RuntimeException: start failed.
01-01 09:30:51.456 8118 8118 E CAM_VideoModule: at android.media.MediaRecorder.start(Native Method)
01-01 09:30:51.456 8118 8118 E CAM_VideoModule: at com.android.camera.VideoModule$11.onStorageUpdateDone(VideoModule.java:1384)
01-01 09:30:51.456 8118 8118 E CAM_VideoModule: at com.android.camera.CameraActivity$22.onPostExecute(CameraActivity.java:2449)
01-01 09:30:51.456 8118 8118 E CAM_VideoModule: at com.android.camera.CameraActivity$22.onPostExecute(CameraActivity.java:2444)
01-01 09:30:51.456 8118 8118 E CAM_VideoModule: at android.os.AsyncTask.finish(AsyncTask.java:651)
01-01 09:30:51.456 8118 8118 E CAM_VideoModule: at android.os.AsyncTask.-wrap1(AsyncTask.java)
01-01 09:30:51.456 8118 8118 E CAM_VideoModule: at android.os.AsyncTask$InternalHandler.handleMessage(AsyncTask.java:668)
01-01 09:30:51.456 8118 8118 E CAM_VideoModule: at android.os.Handler.dispatchMessage(Handler.java:102)
01-01 09:30:51.456 8118 8118 E CAM_VideoModule: at android.os.Looper.loop(Looper.java:148)
01-01 09:30:51.456 8118 8118 E CAM_VideoModule: at android.app.ActivityThread.main(ActivityThread.java:5417)
01-01 09:30:51.456 8118 8118 E CAM_VideoModule: at java.lang.reflect.Method.invoke(Native Method)
01-01 09:30:51.456 8118 8118 E CAM_VideoModule: at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:742)
01-01 09:30:51.456 8118 8118 E CAM_VideoModule: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:632)
01-01 09:30:51.457 8118 8118 E CAM_FatalErrorHandler: Handling Camera Access Failure:
01-01 09:30:51.457 8118 8118 E CAM_FatalErrorHandler: java.lang.Exception
01-01 09:30:51.457 8118 8118 E CAM_FatalErrorHandler: at com.android.camera.FatalErrorHandlerImpl.onGenericCameraAccessFailure(FatalErrorHandlerImpl.java:84)
01-01 09:30:51.457 8118 8118 E CAM_FatalErrorHandler: at com.android.camera.VideoModule$11.onStorageUpdateDone(VideoModule.java:1387)
01-01 09:30:51.457 8118 8118 E CAM_FatalErrorHandler: at com.android.camera.CameraActivity$22.onPostExecute(CameraActivity.java:2449)
01-01 09:30:51.457 8118 8118 E CAM_FatalErrorHandler: at com.android.camera.CameraActivity$22.onPostExecute(CameraActivity.java:2444)
01-01 09:30:51.457 8118 8118 E CAM_FatalErrorHandler: at android.os.AsyncTask.finish(AsyncTask.java:651)
01-01 09:30:51.457 8118 8118 E CAM_FatalErrorHandler: at android.os.AsyncTask.-wrap1(AsyncTask.java)
01-01 09:30:51.457 8118 8118 E CAM_FatalErrorHandler: at android.os.AsyncTask$InternalHandler.handleMessage(AsyncTask.java:668)
01-01 09:30:51.457 8118 8118 E CAM_FatalErrorHandler: at android.os.Handler.dispatchMessage(Handler.java:102)
01-01 09:30:51.457 8118 8118 E CAM_FatalErrorHandler: at android.os.Looper.loop(Looper.java:148)
01-01 09:30:51.457 8118 8118 E CAM_FatalErrorHandler: at android.app.ActivityThread.main(ActivityThread.java:5417)
01-01 09:30:51.457 8118 8118 E CAM_FatalErrorHandler: at java.lang.reflect.Method.invoke(Native Method)
01-01 09:30:51.457 8118 8118 E CAM_FatalErrorHandler: at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:742)
01-01 09:30:51.457 8118 8118 E CAM_FatalErrorHandler: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:632)
01-01 09:30:51.457 8118 8118 E CAM_CameraUtil: Show fatal error dialog
01-01 09:30:51.479 3592 23109 W CameraHardware: unknow focus status: -1
01-01 09:30:51.495 8118 8118 I CAM_VideoModule: Releasing media recorder.
01-01 09:30:51.495 8118 8118 V CAM_VideoModule: Empty video file deleted: /storage/emulated/0/DCIM/Camera/VID_20100101_093051.mp4.tmp
01-01 09:30:51.512 3592 23109 W CameraHardware: unknow focus status: -1
01-01 09:30:51.523 1662 1711 I [Gralloc]: ion_alloc from ion_client:19 via heap type DMA(mask:16) for 460800 Bytes uncached buffer successfully, usage = 0x00000102
01-01 09:30:51.542 3592 23109 W CameraHardware: unknow focus status: -1
01-01 09:30:51.560 1662 6985 I [Gralloc]: ion_alloc from ion_client:19 via heap type DMA(mask:16) for 372992 Bytes uncached buffer successfully, usage = 0x00000f02
01-01 09:30:51.567 1662 3540 I [Gralloc]: ion_alloc from ion_client:19 via heap type DMA(mask:16) for 372992 Bytes uncached buffer successfully, usage = 0x00000f02
01-01 09:30:51.569 1662 3540 I [Gralloc]: ion_alloc from ion_client:19 via heap type DMA(mask:16) for 372992 Bytes uncached buffer successfully, usage = 0x00000f02
01-01 09:30:51.570 1662 3540 I [Gralloc]: ion_alloc from ion_client:19 via heap type DMA(mask:16) for 372992 Bytes uncached buffer successfully, usage = 0x00000f02
01-01 09:30:51.572 3592 23109 W CameraHardware: unknow focus status: -1
01-01 09:30:54.283 3592 23109 W CameraHardware: unknow focus status: -1
01-01 09:30:54.290 3592 4390 V audio_hw_primary: out_set_parameters: routing=2
01-01 09:30:54.291 3592 4390 V audio_hw_primary: out_set_parameters, line: 1561
01-01 09:30:54.291 3592 4390 V audio_hw_primary: >>>>>>>> adev->mode:0,adev->out_device is: 2, val is : 2
01-01 09:30:54.297 1662 6985 I [Gralloc]: ion_alloc from ion_client:19 via heap type DMA(mask:16) for 293760 Bytes cached buffer successfully, usage = 0x00000333
01-01 09:30:54.303 3592 4390 V audio_hw_primary: start_output_stream, line: 1230
01-01 09:30:54.303 3592 4390 D audio_hw_primary: >>>>>> select_device
01-01 09:30:54.304 3592 4390 V audio_hw_primary: active_output, ****LINE:1050,FUNC:select_device, adev->out_device:2
01-01 09:30:54.304 3592 4390 V audio_hw_primary: ****LINE:1056,FUNC:select_device, headset_on:0, headphone_on:0, speaker_on:2, earpiece_on:0, bt_on:0
01-01 09:30:54.304 3592 4390 V audio_hw_primary: ****LINE:1083,FUNC:select_device, output_device_id:6
01-01 09:30:54.304 3592 4390 V audio_hw_primary: NORMAL mode, ****LINE:1087,FUNC:select_device, adev->out_device:2
01-01 09:30:54.305 3592 4390 V audio_hw_primary: start_output_stream: card:0, port:0, rate:44100, period_count:3, period_size:1024
01-01 09:30:54.305 3592 4390 V audio_hw_primary: do not use out resampler
01-01 09:30:54.313 3592 23109 W CameraHardware: unknow focus status: -1
01-01 09:30:54.334 8118 8118 V CAM_QuickActivity: START onPause: Activity = com.android.camera.CameraActivity@849fdfb
01-01 09:30:54.334 8118 8118 V CAM_QuickActivity: onPause --> onPauseTasks()
01-01 09:30:54.334 8118 8118 V CAM_Profiler: 0.000ms][ui] GUARD: CameraActivity.onPause - START
01-01 09:30:54.334 8118 8118 V CAM_VideoModule: stopPreview
01-01 09:30:54.335 3592 7019 D V4L2CameraDevice: V4L2CameraDevice::stopDevice
01-01 09:30:54.335 3592 3845 W CameraHardware: CMD_QUEUE_STOP_FACE_DETECTE failed, mFaceDetection not opened.
01-01 09:30:54.335 3592 7019 W V4L2CameraDevice: wait until capture thread pause or exit
01-01 09:30:54.343 3592 23109 W CameraHardware: unknow focus status: -1
01-01 09:30:54.373 3592 23109 W CameraHardware: unknow focus status: -1
01-01 09:30:54.387 3592 3840 W V4L2CameraDevice: should stop capture now
01-01 09:30:54.388 8118 8118 I CAM_VideoModule: closeCamera
01-01 09:30:54.388 8118 8118 I CAM_VideoModule: Releasing media recorder.
01-01 09:30:54.389 8118 8118 W OrientationEventListener: Cannot detect sensors. Invalid disable
01-01 09:30:54.389 8118 8118 V CAM_LcyLocProvider: stopping location updates
01-01 09:30:54.390 8118 8118 D CAM_LcyLocProvider: stopReceivingLocationUpdates
01-01 09:30:54.390 8118 8118 V CAM_CameraActivity: onPause closing camera
01-01 09:30:54.390 8118 8118 V CAM_CameraController: Closing camera
01-01 09:30:54.391 3592 3845 W CameraHardware: CMD_QUEUE_STOP_FACE_DETECTE failed, mFaceDetection not opened.
01-01 09:30:54.391 3592 6916 W CameraHardware: wait for auto focus thread exit
01-01 09:30:54.403 3592 23109 D CameraHardware: autoFocusThread exited
01-01 09:30:54.426 3592 4390 D AudioFlinger: mixer(0xf23c0000) throttle end: throttle time(33)
01-01 09:30:54.574 3592 23110 D CallbackNotifier: savePictureThread exit, line: 1515
01-01 09:30:54.576 3592 6916 I CameraFlashlight: Destroying camera 0
01-01 09:30:54.680 3592 6916 D HALCameraFactory: There is 1 attached cameras and 0 removable cameras
01-01 09:30:54.682 3592 6916 I CameraService: disconnect: Disconnected client for camera 0 for PID 8118
01-01 09:30:54.683 8118 8118 I CAM_Profiler: [348.659ms][ui] GUARD: CameraActivity.onPause - STOP
01-01 09:30:54.683 8118 8118 V CAM_QuickActivity: END onPause: Activity = com.android.camera.CameraActivity@849fdfb
01-01 09:30:54.683 3592 6787 D NuPlayerDriver: reset(0xf2223900)
01-01 09:30:54.683 3592 6787 D NuPlayerDriver: notifyListener_l(0xf2223900), (8, 0, 0)
01-01 09:30:54.684 3592 23091 D NuPlayerDriver: notifyResetComplete(0xf2223900)
01-01 09:30:54.685 3592 6787 D NuPlayerDriver: reset(0xf22233c0)
01-01 09:30:54.685 3592 6787 D NuPlayerDriver: notifyListener_l(0xf22233c0), (8, 0, 0)
01-01 09:30:54.686 3592 23096 D NuPlayerDriver: notifyResetComplete(0xf22233c0)
01-01 09:30:54.686 1663 1674 D Sayeye : current scense is (Normal)
01-01 09:30:54.686 3592 6787 D NuPlayerDriver: reset(0xf2223420)
01-01 09:30:54.686 3592 6787 D NuPlayerDriver: notifyListener_l(0xf2223420), (8, 0, 0)
01-01 09:30:54.687 1663 1674 E Sayeye : failed to open /sys/devices/soc.0/1c2ac00.twi/i2c-0/0-0040/runtime_suspend, No such file or directory
01-01 09:30:54.687 1663 1674 D Sayeye : Scense (Normal) state set succeed
01-01 09:30:54.689 5340 5422 I DynamicPManagerService: Current Scense:normal
01-01 09:30:54.689 3592 23098 D NuPlayerDriver: notifyResetComplete(0xf2223420)
01-01 09:30:54.725 1662 1711 I [Gralloc]: ion_alloc from ion_client:19 via heap type DMA(mask:16) for 1536000 Bytes uncached buffer successfully, usage = 0x00000f02
01-01 09:30:54.734 1662 6985 I [Gralloc]: ion_alloc from ion_client:19 via heap type DMA(mask:16) for 1536000 Bytes uncached buffer successfully, usage = 0x00000f02
01-01 09:30:54.736 1662 6985 I [Gralloc]: ion_alloc from ion_client:19 via heap type DMA(mask:16) for 1536000 Bytes uncached buffer successfully, usage = 0x00000f02
01-01 09:30:54.739 1662 6985 I [Gralloc]: ion_alloc from ion_client:19 via heap type DMA(mask:16) for 1536000 Bytes uncached buffer successfully, usage = 0x00000f02
01-01 09:30:54.792 8118 8118 V CAM_CameraAppUI: SurfaceTexture is destroyed
01-01 09:30:54.792 8118 8118 V CAM_VideoModule: Skip stopPreview since it’s not mPreviewing
01-01 09:30:54.792 8118 8118 D CAM_VideoUI: surfaceTexture is destroyed
01-01 09:30:54.892 5340 5431 I ActivityManager: Timeline: Activity_windows_visible id: com.android.launcher3 time:3917412
01-01 09:30:54.896 5340 5419 I ActivityManager: Killing 7908:com.android.calendar/u0a20 (adj 15): empty for 3819s
01-01 09:30:54.955 8118 8118 V CAM_QuickActivity: START onStop: Activity = com.android.camera.CameraActivity@849fdfb
01-01 09:30:54.955 8118 8118 D CAM_LcyLocProvider: disconnect
01-01 09:30:54.955 8118 8118 V CAM_QuickActivity: END onStop: Activity = com.android.camera.CameraActivity@849fdfb
01-01 09:30:54.956 8118 8118 V CAM_QuickActivity: START onDestroy: Activity = com.android.camera.CameraActivity@849fdfb
01-01 09:30:54.961 8118 8118 V CAM_QuickActivity: END onDestroy: Activity = com.android.camera.CameraActivity@849fdfb
01-01 09:30:54.968 1663 1674 D Sayeye : current scense is (Normal)
01-01 09:30:54.969 1663 1674 E Sayeye : failed to open /sys/devices/soc.0/1c2ac00.twi/i2c-0/0-0040/runtime_suspend, No such file or directory
01-01 09:30:54.969 1663 1674 D Sayeye : Scense (Normal) state set succeed
01-01 09:30:54.969 5340 5422 I DynamicPManagerService: Current Scense:normal
^C
130|shell@bpi-m64-lcd:/ $
