余弦试用Bananapi M2+ 第一周
安装VNC,结果:
Setting up x11-xserver-utils (7.7+3) …
Setting up xfonts-encodings (1:1.0.4-2) …
Setting up xfonts-utils (1:7.7+2) …
Setting up xfonts-base (1:1.0.3) …
Processing triggers for libc-bin (2.19-18+deb8u4) …
Processing triggers for systemd (215-17+deb8u4) …
E: IO Error to output - fwrite (28: No space left on device)
空间不足?16G的卡,不知到什么问题,继续
[email protected]:/$ vncpasswd
Using password file /home/pi/.vnc/passwd
VNC directory /home/pi/.vnc does not exist, creating.
Error creating directory /home/pi/.vnc: No space left on device
有没有大神知道,用的是树莓系统
QQ 交谈
这个帖子的标题应该是“余弦试用Bananapi M2+遇到的问题一”吧
现在是:
[email protected]:/$ tightvncserver -geometry 800x600 :1
tightvncserver: Could not create /home/pi/.vnc.
炫球说试试sudo raspi-config调整储存,于是我打算今天试试,结果连开机都是问题了,卡机卡这:
7.152596] systemd[1]: Starting Load Kernel Modules...
7.235411] systemd[1]: Starting Create list of required static device nodes for the current kernel...
7.341116] systemd[1]: Mounting Debug File System...
7.430464] systemd[1]: Starting udev Coldplug all Devices...
7.557739] systemd[1]: Started Set Up Additional Binary Formats.
7.574678] systemd[1]: Starting Slices.
7.596058] systemd[1]: Reached target Slices.
7.615739] systemd[1]: Mounted Debug File System.
7.633786] systemd[1]: Mounted POSIX Message Queue File System.
7.726651] systemd[1]: Started Increase datagram queue length.
7.856745] systemd[1]: Started Restore / save the current clock.
7.990517] systemd[1]: Started Load Kernel Modules.
8.070832] systemd[1]: Started Create list of required static device nodes for the current kernel.
8.196808] systemd[1]: Time has been changed
8.213064] systemd[1]: Starting Create Static Device Nodes in /dev...
8.351138] systemd[1]: Mounted Configuration File System.
8.364190] systemd[1]: Starting Apply Kernel Variables...
8.470846] systemd[1]: Mounting FUSE Control File System...
重刷img,使用sudo raspi-config调整储存,解决
