环境 bpi m3
编译过程中开了16线程,cpu 必须安装散热器 ,否则会过热死机
操作系统 rasbian
1.首先下载 git clone https://github.com/BPI-SINOVOIP/BPI-M3-bsp.git
2.添加依赖包 apt-get install git build-essential libncurses5-dev
3.修改BPI-M3-bsp/Makefile 的第8.9行为
CROSS_COMPILE=/usr/bin/arm-linux-gnueabihf-
NEW_CROSS_COMPILE=/usr/bin/arm-linux-gnueabihf-
保存。
4.修改 BPI-M3-bsp/linux-sunxi/arch/arm/mach-sunxi/pm/standby/Makefile
always := standby.code resume1.code
targets := standby.elf resume1.elf
后面加上
hostprogs-y := mksunxichecksum
修改102、103行为
$(obj)/resume1.code: $(obj)/resume1.bin $(obj)/mksunxichecksum
$(obj)/mksunxichecksum $(obj)/resume1.bin $(obj)/super/resume/resume1.code
5在BPI-M3-bsp/linux-sunxi/arch/arm/mach-sunxi/pm/standby/目录下添加
mksunxichecksum.c文件
https://github.com/Themroc/OrangePI-Kernel/blob/37af6ba4e300ef05b347adf1430658ba87320ac8/linux-3.4/arch/arm/mach-sunxi/power/brom/mksunxichecksum.c
[email protected]:/home/pi/emmc/BPI-M3-bsp# ./build.sh
BPI-M3 BSP Build Tool
This tool support following BPI board(s):
- BPI_M3_720P
- BPI_M3_1080P
- BPI_M3_LCD7
- BPI_M3_USB_720P
- BPI_M3_USB_1080P
- BPI_M3_USB_LCD7
Please choose a target(1-6): 1
Now configuring…
BPI_M3_720P configured. Now run make
Configure success!
This tool support following building mode(s):
- Build all, uboot and kernel and pack to download images.
- Build uboot only.
- Build kernel only.
- kernel configure.
- Build rootfs for linux, and copy target files to output
ROOTFS=/xxx/rootfs.tar.gz
This is optinal, default using rootfs/linux/default_linux_rootfs.tar.gz.
- Pack the builds to target download image, this step must execute after u-boot,
kernel and rootfs build out
- Clean all build.
Please choose a mode(1-6): 3
Now building…
make -C linux-sunxi ARCH=arm sun8iw6p1smp_bpi_defconfig
make[1]: Entering directory '/home/pi/emmc/BPI-M3-bsp/linux-sunxi’
drivers/net/wireless/bcmdhd/Kconfig:57:warning: defaults for choice values not supported
configuration written to .config
make[1]: Leaving directory '/home/pi/emmc/BPI-M3-bsp/linux-sunxi’
make -C linux-sunxi ARCH=arm CROSS_COMPILE=/usr/bin/arm-linux-gnueabihf- -j16 INSTALL_MOD_PATH=output uImage modules
scripts/kconfig/conf --silentoldconfig Kconfig
CHK include/linux/version.h
CHK include/generated/utsrelease.h
make[2]: ‘include/generated/mach-types.h’ is up to date.
CALL scripts/checksyscalls.sh
CHK include/generated/compile.h
CC arch/arm/mach-sunxi/pm/standby/common.o
CC arch/arm/mach-sunxi/pm/standby/standby_clock.o
CC arch/arm/mach-sunxi/pm/standby/standby_ir.o
CC arch/arm/mach-sunxi/pm/standby/standby_key.o
CC arch/arm/mach-sunxi/pm/standby/axp209_power.o
CC arch/arm/mach-sunxi/pm/standby/standby_power.o
CC arch/arm/mach-sunxi/pm/standby/standby_twi.o
CC arch/arm/mach-sunxi/pm/standby/standby_usb.o
AS arch/arm/mach-sunxi/pm/standby/standby_delay.o
CC arch/arm/mach-sunxi/pm/standby/./…/pm_debug.o
CC arch/arm/mach-sunxi/pm/standby/./…/mem_timing.o
CC arch/arm/mach-sunxi/pm/standby/./…/mem_mmu_pc.o
AS arch/arm/mach-sunxi/pm/standby/./…/mem_mmu_pc_asm.o
CC arch/arm/mach-sunxi/pm/standby/./…/mem_serial.o
CC arch/arm/mach-sunxi/pm/standby/./…/mem_printk.o
AS arch/arm/mach-sunxi/pm/standby/./…/mem_divlib.o
CC arch/arm/mach-sunxi/pm/standby/./…/mem_divlibc.o
CC arch/arm/mach-sunxi/pm/standby/./…/mem_int.o
CC arch/arm/mach-sunxi/pm/standby/./…/mem_gpio.o
CC arch/arm/mach-sunxi/pm/standby/./…/mem_tmr.o
CC arch/arm/mach-sunxi/pm/standby/./…/mem_tmstmp.o
CC arch/arm/mach-sunxi/pm/standby/./…/mem_clk.o
CC arch/arm/mach-sunxi/pm/standby/standby.o
CC arch/arm/mach-sunxi/pm/standby/./arisc/standby_arisc.o
CC arch/arm/mach-sunxi/pm/standby/./arisc/arisc_hwmsgbox.o
CC arch/arm/mach-sunxi/pm/standby/./arisc/arisc_hwspinlock.o
CC arch/arm/mach-sunxi/pm/standby/./arisc/arisc_message_manager.o
CC arch/arm/mach-sunxi/pm/standby/./…/mem_hwspinlock.o
rm -rf .o arch/arm/mach-sunxi/pm/standby/…/.o
CC arch/arm/mach-sunxi/pm/standby/super/common.o
CC arch/arm/mach-sunxi/pm/standby/super/super_twi.o
AS arch/arm/mach-sunxi/pm/standby/super/super_delay.o
CC arch/arm/mach-sunxi/pm/standby/super/super_clock.o
CC arch/arm/mach-sunxi/pm/standby/super/super_power.o
CC arch/arm/mach-sunxi/pm/standby/super/super_cpus.o
AS arch/arm/mach-sunxi/pm/standby/super/resume/resume1.o
CC arch/arm/mach-sunxi/pm/standby/super/resume/resume_head.o
CC arch/arm/mach-sunxi/pm/standby/super/resume/resume1_c_part.o
CC arch/arm/mach-sunxi/pm/standby/…/pm_debug.o
CC arch/arm/mach-sunxi/pm/standby/…/mem_timing.o
CC arch/arm/mach-sunxi/pm/standby/…/mem_mmu_pc.o
AS arch/arm/mach-sunxi/pm/standby/…/mem_mmu_pc_asm.o
CC arch/arm/mach-sunxi/pm/standby/…/mem_cpu.o
CC arch/arm/mach-sunxi/pm/standby/…/mem_serial.o
CC arch/arm/mach-sunxi/pm/standby/…/mem_printk.o
AS arch/arm/mach-sunxi/pm/standby/…/mem_divlib.o
CC arch/arm/mach-sunxi/pm/standby/…/mem_divlibc.o
CC arch/arm/mach-sunxi/pm/standby/…/mem_int.o
CC arch/arm/mach-sunxi/pm/standby/…/mem_gpio.o
CC arch/arm/mach-sunxi/pm/standby/…/mem_tmr.o
CC arch/arm/mach-sunxi/pm/standby/…/mem_tmstmp.o
CC arch/arm/mach-sunxi/pm/standby/…/mem_hwspinlock.o
CC arch/arm/mach-sunxi/pm/standby/…/mem_clk.o
arch/arm/mach-sunxi/pm/standby/mksunxichecksum arch/arm/mach-sunxi/pm/standby/resume1.bin arch/arm/mach-sunxi/pm/standby/super/resume/resume1.code
CC arch/arm/mach-sunxi/pm/mem_mapping.o
CC arch/arm/mach-sunxi/pm/mem_divlibc.o
CC arch/arm/mach-sunxi/pm/mem_cpu.o
AS arch/arm/mach-sunxi/pm/mem_cpu_asm.o
AS arch/arm/mach-sunxi/pm/mem_mmu_pc_asm.o
CC arch/arm/mach-sunxi/pm/mem_mmu_pc.o
CC arch/arm/mach-sunxi/pm/mem_int.o
CC arch/arm/mach-sunxi/pm/mem_clk.o
CC arch/arm/mach-sunxi/pm/mem_serial.o
CC arch/arm/mach-sunxi/pm/mem_key.o
CC arch/arm/mach-sunxi/pm/mem_ir.o
CC arch/arm/mach-sunxi/pm/mem_usb.o
CC arch/arm/mach-sunxi/pm/mem_tmr.o
CC arch/arm/mach-sunxi/pm/mem_tmstmp.o
CC arch/arm/mach-sunxi/pm/mem_twi.o
CC arch/arm/mach-sunxi/pm/mem_gpio.o
CC arch/arm/mach-sunxi/pm/mem_sram.o
CC arch/arm/mach-sunxi/pm/mem_ccu.o
CC arch/arm/mach-sunxi/pm/mem_cci400.o
CC arch/arm/mach-sunxi/pm/mem_gtbus.o
CC arch/arm/mach-sunxi/pm/pm_debug.o
CC arch/arm/mach-sunxi/pm/pm_debug_secure.o
CC arch/arm/mach-sunxi/pm/mem_timing.o
CC arch/arm/mach-sunxi/pm/mem_hwspinlock.o
CC arch/arm/mach-sunxi/pm/pm.o
AS arch/arm/mach-sunxi/pm/mem.o
AS arch/arm/mach-sunxi/pm/standby.o
CC arch/arm/mach-sunxi/pm/aw_pm.o
CC arch/arm/mach-sunxi/pm/aw_pwr_dm.o
CC arch/arm/mach-sunxi/pm/extended_standby-sun8iw6.o
LD arch/arm/mach-sunxi/pm/pm_tmp.o
LD arch/arm/mach-sunxi/pm/built-in.o
LD arch/arm/mach-sunxi/built-in.o
LD vmlinux.o
MODPOST vmlinux.o
WARNING: modpost: Found 23 section mismatch(es).
To see full details build your kernel with:
'make CONFIG_DEBUG_SECTION_MISMATCH=y’
GEN .version
UPD include/generated/compile.h
CC init/version.o
LD init/built-in.o
LD .tmp_vmlinux1
KSYM .tmp_kallsyms1.S
AS .tmp_kallsyms1.o
LD .tmp_vmlinux2
KSYM .tmp_kallsyms2.S
AS .tmp_kallsyms2.o
LD vmlinux
SYSMAP System.map
SYSMAP .tmp_System.map
OBJCOPY arch/arm/boot/Image
Building modules, stage 2.
Kernel: arch/arm/boot/Image is ready
GZIP arch/arm/boot/compressed/piggy.gzip
MODPOST 953 modules
AS arch/arm/boot/compressed/piggy.gzip.o
WARNING: could not find drivers/media/video/sunxi-vfe/lib/.libisp.cmd for drivers/media/video/sunxi-vfe/lib/libisp
LD arch/arm/boot/compressed/vmlinux
OBJCOPY arch/arm/boot/zImage
Kernel: arch/arm/boot/zImage is ready
UIMAGE arch/arm/boot/uImage
Image Name: Linux-3.4.39-BPI-M3-Kernel
Created: Sat Jul 23 16:42:52 2016
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 5723952 Bytes = 5589.80 kB = 5.46 MB
Load Address: 40008000
Entry Point: 40008000
Image arch/arm/boot/uImage is ready
WARNING: modpost: Found 1 section mismatch(es).
make -C linux-sunxi/modules/gpu CROSS_COMPILE=/usr/bin/arm-linux-gnueabihf- ARCH=arm LICHEE_KDIR=/home/pi/emmc/BPI-M3-bsp/linux-sunxi
make[1]: Entering directory '/home/pi/emmc/BPI-M3-bsp/linux-sunxi/modules/gpu’
make -j -C sgx544/android/kernel_mode/eurasia_km/eurasiacon/build/linux2/sunxi_linux BUILD=release KERNELDIR=/home/pi/emmc/BPI-M3-bsp/linux-sunxi
make[2]: Entering directory '/home/pi/emmc/BPI-M3-bsp/linux-sunxi/modules/gpu/sgx544/android/kernel_mode/eurasia_km/eurasiacon/build/linux2/sunxi_linux’
MODPOST 2 modules
make[2]: Leaving directory '/home/pi/emmc/BPI-M3-bsp/linux-sunxi/modules/gpu/sgx544/android/kernel_mode/eurasia_km/eurasiacon/build/linux2/sunxi_linux’
make[1]: Leaving directory '/home/pi/emmc/BPI-M3-bsp/linux-sunxi/modules/gpu’
make -C linux-sunxi ARCH=arm CROSS_COMPILE=/usr/bin/arm-linux-gnueabihf- -j16 INSTALL_MOD_PATH=output modules_install
INSTALL crypto/async_tx/async_memcpy.ko
INSTALL crypto/async_tx/async_pq.ko
INSTALL crypto/async_tx/async_raid6_recov.ko
INSTALL crypto/async_tx/async_tx.ko
INSTALL crypto/async_tx/async_xor.ko
INSTALL drivers/block/aoe/aoe.ko
INSTALL drivers/bluetooth/bcm_btlpm.ko
INSTALL drivers/block/nbd.ko
INSTALL crypto/xor.ko
INSTALL drivers/block/osdblk.ko
INSTALL drivers/bluetooth/btmrvl_sdio.ko
INSTALL drivers/bluetooth/btmrvl.ko
INSTALL drivers/char/hw_random/timeriomem-rng.ko
INSTALL drivers/char/tpm/tpm.ko
INSTALL drivers/char/ipmi/ipmi_msghandler.ko
INSTALL drivers/char/ipmi/ipmi_si.ko
INSTALL drivers/crypto/sunxi/ss.ko
INSTALL drivers/char/sunxi_tr/sunxi_tr.ko
INSTALL drivers/gpio/gpio-sunxi.ko
INSTALL drivers/hid/hid-elecom.ko
INSTALL drivers/hid/hid-magicmouse.ko
INSTALL drivers/hwmon/ad7418.ko
INSTALL drivers/hwmon/adm1021.ko
INSTALL drivers/hid/hid-wacom.ko
INSTALL drivers/hwmon/ad7314.ko
INSTALL drivers/hwmon/adcxx.ko
INSTALL drivers/hwmon/adm1026.ko
INSTALL drivers/hwmon/ad7414.ko
INSTALL drivers/hwmon/adm1031.ko
INSTALL drivers/hwmon/ads7871.ko
INSTALL drivers/hwmon/adm1029.ko
INSTALL drivers/hwmon/adm1025.ko
INSTALL drivers/hwmon/ads1015.ko
INSTALL drivers/hwmon/ads7828.ko
INSTALL drivers/hwmon/adm9240.ko
INSTALL drivers/hwmon/adt7411.ko
INSTALL drivers/hwmon/adt7462.ko
INSTALL drivers/hwmon/adt7470.ko
INSTALL drivers/hwmon/adt7475.ko
INSTALL drivers/hwmon/afa750.ko
INSTALL drivers/hwmon/asc7621.ko
INSTALL drivers/hwmon/amc6821.ko
INSTALL drivers/hwmon/bma250.ko
INSTALL drivers/hwmon/dme1737.ko
INSTALL drivers/hwmon/atxp1.ko
INSTALL drivers/hwmon/emc1403.ko
INSTALL drivers/hwmon/ds1621.ko
INSTALL drivers/hwmon/emc2103.ko
INSTALL drivers/hwmon/emc6w201.ko
INSTALL drivers/hwmon/ds620.ko
INSTALL drivers/hwmon/f71805f.ko
INSTALL drivers/hwmon/f71882fg.ko
INSTALL drivers/hwmon/g760a.ko
INSTALL drivers/hwmon/f75375s.ko
INSTALL drivers/hwmon/gl518sm.ko
INSTALL drivers/hwmon/gl520sm.ko
INSTALL drivers/hwmon/ibmaem.ko
INSTALL drivers/hwmon/gpio-fan.ko
INSTALL drivers/hwmon/ibmpex.ko
INSTALL drivers/hwmon/hwmon-vid.ko
INSTALL drivers/hwmon/ina219.ko
INSTALL drivers/hwmon/it87.ko
INSTALL drivers/hwmon/jc42.ko
INSTALL drivers/hwmon/lineage-pem.ko
INSTALL drivers/hwmon/kionix_tiny.ko
INSTALL drivers/hwmon/lis3dh_acc.ko
INSTALL drivers/hwmon/lm73.ko
INSTALL drivers/hwmon/lm63.ko
INSTALL drivers/hwmon/lm70.ko
INSTALL drivers/hwmon/lm78.ko
INSTALL drivers/hwmon/lm80.ko
INSTALL drivers/hwmon/lm75.ko
INSTALL drivers/hwmon/lm77.ko
INSTALL drivers/hwmon/lis3de_acc.ko
INSTALL drivers/hwmon/lm83.ko
INSTALL drivers/hwmon/lm85.ko
INSTALL drivers/hwmon/lm87.ko
INSTALL drivers/hwmon/lm90.ko
INSTALL drivers/hwmon/lm92.ko
INSTALL drivers/hwmon/lm93.ko
INSTALL drivers/hwmon/lm95241.ko
INSTALL drivers/hwmon/lm95245.ko
INSTALL drivers/hwmon/ltc4215.ko
INSTALL drivers/hwmon/ltc4245.ko
INSTALL drivers/hwmon/ltc4151.ko
INSTALL drivers/hwmon/max1668.ko
INSTALL drivers/hwmon/max1619.ko
INSTALL drivers/hwmon/max16065.ko
INSTALL drivers/hwmon/ltc4261.ko
INSTALL drivers/hwmon/max6642.ko
INSTALL drivers/hwmon/max1111.ko
INSTALL drivers/hwmon/max6650.ko
INSTALL drivers/hwmon/max6639.ko
INSTALL drivers/hwmon/mma8452.ko
INSTALL drivers/hwmon/mma7660.ko
INSTALL drivers/hwmon/mcp3021.ko
INSTALL drivers/hwmon/mma865x.ko
INSTALL drivers/hwmon/ntc_thermistor.ko
INSTALL drivers/hwmon/pc87360.ko
INSTALL drivers/hwmon/pc87427.ko
INSTALL drivers/hwmon/pcf8591.ko
INSTALL drivers/hwmon/pmbus/pmbus.ko
INSTALL drivers/hwmon/pmbus/pmbus_core.ko
INSTALL drivers/hwmon/sch5627.ko
INSTALL drivers/hwmon/sch56xx-common.ko
INSTALL drivers/hwmon/sch5636.ko
INSTALL drivers/hwmon/sht21.ko
INSTALL drivers/hwmon/sht15.ko
INSTALL drivers/hwmon/smsc47m1.ko
INSTALL drivers/hwmon/smm665.ko
INSTALL drivers/hwmon/smsc47b397.ko
INSTALL drivers/hwmon/thmc50.ko
INSTALL drivers/hwmon/smsc47m192.ko
INSTALL drivers/hwmon/tmp401.ko
INSTALL drivers/hwmon/tmp102.ko
INSTALL drivers/hwmon/tmp421.ko
INSTALL drivers/hwmon/vt1211.ko
INSTALL drivers/hwmon/w83627hf.ko
INSTALL drivers/hwmon/w83781d.ko
INSTALL drivers/hwmon/w83627ehf.ko
INSTALL drivers/hwmon/w83791d.ko
INSTALL drivers/hwmon/w83793.ko
INSTALL drivers/hwmon/w83795.ko
INSTALL drivers/hwmon/w83792d.ko
INSTALL drivers/hwmon/w83l786ng.ko
INSTALL drivers/hwmon/w83l785ts.ko
INSTALL drivers/input/gameport/lightning.ko
INSTALL drivers/input/gameport/ns558.ko
INSTALL drivers/input/gameport/gameport.ko
INSTALL drivers/input/joystick/a3d.ko
INSTALL drivers/input/joystick/adi.ko
INSTALL drivers/input/joystick/as5011.ko
INSTALL drivers/input/joystick/analog.ko
INSTALL drivers/input/joystick/cobra.ko
INSTALL drivers/input/joystick/grip.ko
INSTALL drivers/input/joystick/grip_mp.ko
INSTALL drivers/input/joystick/gf2k.ko
INSTALL drivers/input/joystick/iforce/iforce.ko
INSTALL drivers/input/joystick/guillemot.ko
INSTALL drivers/input/joystick/interact.ko
INSTALL drivers/input/joystick/joydump.ko
INSTALL drivers/input/joystick/sidewinder.ko
INSTALL drivers/input/joystick/magellan.ko
INSTALL drivers/input/joystick/spaceorb.ko
INSTALL drivers/input/joystick/tmdc.ko
INSTALL drivers/input/joystick/stinger.ko
INSTALL drivers/input/joystick/spaceball.ko
INSTALL drivers/input/joystick/xpad.ko
INSTALL drivers/input/joystick/twidjoy.ko
INSTALL drivers/input/joystick/zhenhua.ko
INSTALL drivers/input/joystick/warrior.ko
INSTALL drivers/input/keyboard/adp5589-keys.ko
INSTALL drivers/input/keyboard/lkkbd.ko
INSTALL drivers/input/keyboard/adp5588-keys.ko
INSTALL drivers/input/keyboard/lm8323.ko
INSTALL drivers/input/keyboard/max7359_keypad.ko
INSTALL drivers/input/keyboard/mcs_touchkey.ko
INSTALL drivers/input/keyboard/mpr121_touchkey.ko
INSTALL drivers/input/keyboard/omap4-keypad.ko
INSTALL drivers/input/keyboard/newtonkbd.ko
INSTALL drivers/input/keyboard/qt1070.ko
INSTALL drivers/input/keyboard/opencores-kbd.ko
INSTALL drivers/input/keyboard/sunkbd.ko
INSTALL drivers/input/keyboard/stowaway.ko
INSTALL drivers/input/keyboard/tca8418_keypad.ko
INSTALL drivers/input/keyboard/sunxi-ir-rx.ko
INSTALL drivers/input/keyboard/tca6416-keypad.ko
INSTALL drivers/input/keyboard/xtkbd.ko
INSTALL drivers/input/mouse/appletouch.ko
INSTALL drivers/input/mouse/sermouse.ko
INSTALL drivers/input/mouse/bcm5974.ko
INSTALL drivers/input/mouse/synaptics_i2c.ko
INSTALL drivers/input/mouse/vsxxxaa.ko
INSTALL drivers/input/mouse/synaptics_usb.ko
INSTALL drivers/input/serio/altera_ps2.ko
INSTALL drivers/input/tablet/acecad.ko
INSTALL drivers/input/serio/serio_raw.ko
INSTALL drivers/input/serio/ps2mult.ko
INSTALL drivers/input/tablet/aiptek.ko
INSTALL drivers/input/tablet/hanwang.ko
INSTALL drivers/input/tablet/kbtab.ko
INSTALL drivers/input/tablet/gtco.ko
INSTALL drivers/input/touchscreen/usbtouchscreen.ko
INSTALL drivers/input/touchscreen/gt927/gt9xx_ts.ko
INSTALL drivers/input/touchscreen/ft5x/ft5x_ts.ko
INSTALL drivers/isdn/capi/kernelcapi.ko
INSTALL drivers/isdn/gigaset/gigaset.ko
INSTALL drivers/md/dm-crypt.ko
INSTALL drivers/isdn/mISDN/mISDN_core.ko
INSTALL drivers/md/dm-bufio.ko
INSTALL drivers/md/dm-log.ko
INSTALL drivers/md/dm-mod.ko
INSTALL drivers/md/dm-mirror.ko
INSTALL drivers/md/dm-queue-length.ko
INSTALL drivers/md/dm-raid.ko
INSTALL drivers/md/dm-snapshot.ko
INSTALL drivers/md/dm-round-robin.ko
INSTALL drivers/md/dm-multipath.ko
INSTALL drivers/md/dm-region-hash.ko
INSTALL drivers/md/dm-service-time.ko
INSTALL drivers/md/dm-thin-pool.ko
INSTALL drivers/md/md-mod.ko
INSTALL drivers/md/linear.ko
INSTALL drivers/md/persistent-data/dm-persistent-data.ko
INSTALL drivers/md/raid0.ko
INSTALL drivers/md/dm-zero.ko
INSTALL drivers/md/raid1.ko
INSTALL drivers/md/raid456.ko
INSTALL drivers/md/raid10.ko
INSTALL drivers/media/common/tuners/mt2060.ko
INSTALL drivers/media/common/tuners/max2165.ko
INSTALL drivers/media/common/tuners/mt2063.ko
INSTALL drivers/media/common/tuners/mt2266.ko
INSTALL drivers/media/common/tuners/mt2131.ko
INSTALL drivers/media/common/tuners/mxl5005s.ko
INSTALL drivers/media/common/tuners/qt1010.ko
INSTALL drivers/media/common/tuners/tda18212.ko
INSTALL drivers/media/common/tuners/mxl5007t.ko
INSTALL drivers/media/common/tuners/tda18218.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-a800.ko
INSTALL drivers/media/dvb/b2c2/b2c2-flexcop.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-au6610.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-af9015.ko
INSTALL drivers/media/dvb/b2c2/b2c2-flexcop-usb.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-anysee.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-az6007.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-ce6230.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-az6027.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-cinergyT2.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-dib0700.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-cxusb.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-dibusb-common.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-dibusb-mb.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-dibusb-mc.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-dtt200u.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-digitv.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-dw2102.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-dtv5100.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-friio.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-ec168.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-gl861.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-m920x.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-lmedm04.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-gp8psk.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-mxl111sf.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-nova-t-usb2.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-pctv452e.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-opera.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-technisat-usb2.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-ttusb2.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-umt-010.ko
INSTALL drivers/media/dvb/dvb-usb/mxl111sf-demod.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-vp702x.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb.ko
INSTALL drivers/media/dvb/dvb-usb/dvb-usb-vp7045.ko
INSTALL drivers/media/dvb/dvb-usb/mxl111sf-tuner.ko
INSTALL drivers/media/dvb/frontends/af9013.ko
INSTALL drivers/media/dvb/frontends/a8293.ko
INSTALL drivers/media/dvb/frontends/atbm8830.ko
INSTALL drivers/media/dvb/frontends/bcm3510.ko
INSTALL drivers/media/dvb/frontends/au8522.ko
INSTALL drivers/media/dvb/frontends/cx22700.ko
INSTALL drivers/media/dvb/frontends/cx24113.ko
INSTALL drivers/media/dvb/frontends/cx22702.ko
INSTALL drivers/media/dvb/frontends/cx24110.ko
INSTALL drivers/media/dvb/frontends/cx24123.ko
INSTALL drivers/media/dvb/frontends/cx24116.ko
INSTALL drivers/media/dvb/frontends/cxd2820r.ko
INSTALL drivers/media/dvb/frontends/dib0090.ko
INSTALL drivers/media/dvb/frontends/dib0070.ko
INSTALL drivers/media/dvb/frontends/dib3000mb.ko
INSTALL drivers/media/dvb/frontends/dib7000m.ko
INSTALL drivers/media/dvb/frontends/dib7000p.ko
INSTALL drivers/media/dvb/frontends/dib3000mc.ko
INSTALL drivers/media/dvb/frontends/dib8000.ko
INSTALL drivers/media/dvb/frontends/dib9000.ko
INSTALL drivers/media/dvb/frontends/dibx000_common.ko
INSTALL drivers/media/dvb/frontends/drxd.ko
INSTALL drivers/media/dvb/frontends/drxk.ko
INSTALL drivers/media/dvb/frontends/ds3000.ko
INSTALL drivers/media/dvb/frontends/dvb-pll.ko
INSTALL drivers/media/dvb/frontends/ec100.ko
INSTALL drivers/media/dvb/frontends/isl6405.ko
INSTALL drivers/media/dvb/frontends/hd29l2.ko
INSTALL drivers/media/dvb/frontends/isl6423.ko
INSTALL drivers/media/dvb/frontends/it913x-fe.ko
INSTALL drivers/media/dvb/frontends/isl6421.ko
INSTALL drivers/media/dvb/frontends/itd1000.ko
INSTALL drivers/media/dvb/frontends/ix2505v.ko
INSTALL drivers/media/dvb/frontends/lgdt3305.ko
INSTALL drivers/media/dvb/frontends/l64781.ko
INSTALL drivers/media/dvb/frontends/lgdt330x.ko
INSTALL drivers/media/dvb/frontends/lgs8gxx.ko
INSTALL drivers/media/dvb/frontends/lgs8gl5.ko
INSTALL drivers/media/dvb/frontends/lnbp21.ko
INSTALL drivers/media/dvb/frontends/lnbp22.ko
INSTALL drivers/media/dvb/frontends/m88rs2000.ko
INSTALL drivers/media/dvb/frontends/mb86a16.ko
INSTALL drivers/media/dvb/frontends/mb86a20s.ko
INSTALL drivers/media/dvb/frontends/mt312.ko
INSTALL drivers/media/dvb/frontends/mt352.ko
INSTALL drivers/media/dvb/frontends/nxt6000.ko
INSTALL drivers/media/dvb/frontends/nxt200x.ko
INSTALL drivers/media/dvb/frontends/or51132.ko
INSTALL drivers/media/dvb/frontends/s5h1409.ko
INSTALL drivers/media/dvb/frontends/rtl2830.ko
INSTALL drivers/media/dvb/frontends/or51211.ko
INSTALL drivers/media/dvb/frontends/s5h1411.ko
INSTALL drivers/media/dvb/frontends/s5h1420.ko
INSTALL drivers/media/dvb/frontends/s5h1432.ko
INSTALL drivers/media/dvb/frontends/si21xx.ko
INSTALL drivers/media/dvb/frontends/s921.ko
INSTALL drivers/media/dvb/frontends/sp887x.ko
INSTALL drivers/media/dvb/frontends/stb0899.ko
INSTALL drivers/media/dvb/frontends/stb6000.ko
INSTALL drivers/media/dvb/frontends/sp8870.ko
INSTALL drivers/media/dvb/frontends/stb6100.ko
INSTALL drivers/media/dvb/frontends/stv0288.ko
INSTALL drivers/media/dvb/frontends/stv0297.ko
INSTALL drivers/media/dvb/frontends/stv0299.ko
INSTALL drivers/media/dvb/frontends/stv0367.ko
INSTALL drivers/media/dvb/frontends/stv090x.ko
INSTALL drivers/media/dvb/frontends/stv0900.ko
INSTALL drivers/media/dvb/frontends/stv6110.ko
INSTALL drivers/media/dvb/frontends/tda10021.ko
INSTALL drivers/media/dvb/frontends/tda10023.ko
INSTALL drivers/media/dvb/frontends/stv6110x.ko
INSTALL drivers/media/dvb/frontends/tda1004x.ko
INSTALL drivers/media/dvb/frontends/tda10086.ko
INSTALL drivers/media/dvb/frontends/tda10048.ko
INSTALL drivers/media/dvb/frontends/tda18271c2dd.ko
INSTALL drivers/media/dvb/frontends/tda8083.ko
INSTALL drivers/media/dvb/frontends/tda665x.ko
INSTALL drivers/media/dvb/frontends/tda8261.ko
INSTALL drivers/media/dvb/frontends/tda10071.ko
INSTALL drivers/media/dvb/frontends/tda826x.ko
INSTALL drivers/media/dvb/frontends/tua6100.ko
INSTALL drivers/media/dvb/frontends/ves1820.ko
INSTALL drivers/media/dvb/frontends/ves1x93.ko
INSTALL drivers/media/dvb/frontends/zl10039.ko
INSTALL drivers/media/dvb/frontends/zl10353.ko
INSTALL drivers/media/dvb/frontends/zl10036.ko
INSTALL drivers/media/dvb/siano/smsdvb.ko
INSTALL drivers/media/dvb/siano/smsmdtv.ko
INSTALL drivers/media/dvb/siano/smssdio.ko
INSTALL drivers/media/dvb/siano/smsusb.ko
INSTALL drivers/media/dvb/ttpci/ttpci-eeprom.ko
INSTALL drivers/media/radio/dsbr100.ko
INSTALL drivers/media/radio/radio-mr800.ko
INSTALL drivers/media/radio/radio-keene.ko
INSTALL drivers/media/radio/radio-si4713.ko
INSTALL drivers/media/radio/radio-tea5764.ko
INSTALL drivers/media/radio/radio-wl1273.ko
INSTALL drivers/media/radio/tef6862.ko
INSTALL drivers/media/radio/saa7706h.ko
INSTALL drivers/media/radio/si4713-i2c.ko
INSTALL drivers/media/rc/ati_remote.ko
INSTALL drivers/media/rc/gpio-ir-recv.ko
INSTALL drivers/media/rc/mceusb.ko
INSTALL drivers/media/rc/rc-loopback.ko
INSTALL drivers/media/rc/imon.ko
INSTALL drivers/media/rc/redrat3.ko
INSTALL drivers/media/rc/streamzap.ko
INSTALL drivers/media/video/cpia2/cpia2.ko
INSTALL drivers/media/video/cx231xx/cx231xx.ko
INSTALL drivers/media/video/cx231xx/cx231xx-alsa.ko
INSTALL drivers/media/video/cx231xx/cx231xx-dvb.ko
INSTALL drivers/media/video/cx2341x.ko
INSTALL drivers/media/video/cs53l32a.ko
INSTALL drivers/media/video/cx25840/cx25840.ko
INSTALL drivers/media/video/gspca/gl860/gspca_gl860.ko
INSTALL drivers/media/video/em28xx/em28xx.ko
INSTALL drivers/media/video/em28xx/em28xx-alsa.ko
INSTALL drivers/media/video/gspca/gspca_benq.ko
INSTALL drivers/media/video/em28xx/em28xx-dvb.ko
INSTALL drivers/media/video/gspca/gspca_conex.ko
INSTALL drivers/media/video/gspca/gspca_etoms.ko
INSTALL drivers/media/video/gspca/gspca_cpia1.ko
INSTALL drivers/media/video/gspca/gspca_jeilinj.ko
INSTALL drivers/media/video/gspca/gspca_finepix.ko
INSTALL drivers/media/video/gspca/gspca_jl2005bcd.ko
INSTALL drivers/media/video/gspca/gspca_kinect.ko
INSTALL drivers/media/video/gspca/gspca_main.ko
INSTALL drivers/media/video/gspca/gspca_mars.ko
INSTALL drivers/media/video/gspca/gspca_konica.ko
INSTALL drivers/media/video/gspca/gspca_nw80x.ko
INSTALL drivers/media/video/gspca/gspca_ov519.ko
INSTALL drivers/media/video/gspca/gspca_ov534.ko
INSTALL drivers/media/video/gspca/gspca_mr97310a.ko
INSTALL drivers/media/video/gspca/gspca_pac7302.ko
INSTALL drivers/media/video/gspca/gspca_pac207.ko
INSTALL drivers/media/video/gspca/gspca_ov534_9.ko
INSTALL drivers/media/video/gspca/gspca_se401.ko
INSTALL drivers/media/video/gspca/gspca_pac7311.ko
INSTALL drivers/media/video/gspca/gspca_sn9c2028.ko
INSTALL drivers/media/video/gspca/gspca_sn9c20x.ko
INSTALL drivers/media/video/gspca/gspca_sonixb.ko
INSTALL drivers/media/video/gspca/gspca_sonixj.ko
INSTALL drivers/media/video/gspca/gspca_spca1528.ko
INSTALL drivers/media/video/gspca/gspca_spca500.ko
INSTALL drivers/media/video/gspca/gspca_spca501.ko
INSTALL drivers/media/video/gspca/gspca_spca505.ko
INSTALL drivers/media/video/gspca/gspca_spca506.ko
INSTALL drivers/media/video/gspca/gspca_spca561.ko
INSTALL drivers/media/video/gspca/gspca_spca508.ko
INSTALL drivers/media/video/gspca/gspca_sq905c.ko
INSTALL drivers/media/video/gspca/gspca_sq905.ko
INSTALL drivers/media/video/gspca/gspca_sq930x.ko
INSTALL drivers/media/video/gspca/gspca_stk014.ko
INSTALL drivers/media/video/gspca/gspca_stv0680.ko
INSTALL drivers/media/video/gspca/gspca_sunplus.ko
INSTALL drivers/media/video/gspca/gspca_t613.ko
INSTALL drivers/media/video/gspca/gspca_tv8532.ko
INSTALL drivers/media/video/gspca/gspca_topro.ko
INSTALL drivers/media/video/gspca/gspca_vc032x.ko
INSTALL drivers/media/video/gspca/gspca_xirlink_cit.ko
INSTALL drivers/media/video/gspca/gspca_zc3xx.ko
INSTALL drivers/media/video/gspca/gspca_vicam.ko
INSTALL drivers/media/video/gspca/m5602/gspca_m5602.ko
INSTALL drivers/media/video/hdpvr/hdpvr.ko
INSTALL drivers/media/video/gspca/stv06xx/gspca_stv06xx.ko
INSTALL drivers/media/video/imx074.ko
INSTALL drivers/media/video/mt9m001.ko
INSTALL drivers/media/video/mt9t112.ko
INSTALL drivers/media/video/msp3400.ko
INSTALL drivers/media/video/mt9t031.ko
INSTALL drivers/media/video/mt9m111.ko
INSTALL drivers/media/video/mt9v022.ko
INSTALL drivers/media/video/ov2640.ko
INSTALL drivers/media/video/mt9v011.ko
INSTALL drivers/media/video/ov7670.ko
INSTALL drivers/media/video/ov772x.ko
INSTALL drivers/media/video/ov6650.ko
INSTALL drivers/media/video/ov9740.ko
INSTALL drivers/media/video/ov5642.ko
INSTALL drivers/media/video/pvrusb2/pvrusb2.ko
INSTALL drivers/media/video/ov9640.ko
INSTALL drivers/media/video/pwc/pwc.ko
INSTALL drivers/media/video/rj54n1cb0c.ko
INSTALL drivers/media/video/sh_mobile_ceu_camera.ko
INSTALL drivers/media/video/sh_mobile_csi2.ko
INSTALL drivers/media/video/s2255drv.ko
INSTALL drivers/media/video/saa7115.ko
INSTALL drivers/media/video/soc_camera.ko
INSTALL drivers/media/video/soc_mediabus.ko
INSTALL drivers/media/video/sunxi-vfe/actuator/ad5820_act.ko
INSTALL drivers/media/video/sunxi-vfe/actuator/actuator.ko
INSTALL drivers/media/video/soc_camera_platform.ko
INSTALL drivers/media/video/sunxi-vfe/actuator/dw9714_act.ko
INSTALL drivers/media/video/sunxi-vfe/actuator/vm149c_act.ko
INSTALL drivers/media/video/sunxi-vfe/actuator/ov8825_act.ko
INSTALL drivers/media/video/sunxi-vfe/csi_cci/cci.ko
INSTALL drivers/media/video/sunxi-vfe/device/ar0330.ko
INSTALL drivers/media/video/sunxi-vfe/device/bg0703.ko
INSTALL drivers/media/video/sunxi-vfe/device/gc0307.ko
INSTALL drivers/media/video/sunxi-vfe/device/gc0311.ko
INSTALL drivers/media/video/sunxi-vfe/device/gc0308.ko
INSTALL drivers/media/video/sunxi-vfe/device/gc0328.ko
INSTALL drivers/media/video/sunxi-vfe/device/gc1014_mipi.ko
INSTALL drivers/media/video/sunxi-vfe/device/gc2155.ko
INSTALL drivers/media/video/sunxi-vfe/device/gc0329.ko
INSTALL drivers/media/video/sunxi-vfe/device/gc2035.ko
INSTALL drivers/media/video/sunxi-vfe/device/gt2005.ko
INSTALL drivers/media/video/sunxi-vfe/device/gc5004_mipi.ko
INSTALL drivers/media/video/sunxi-vfe/device/hi253.ko
INSTALL drivers/media/video/sunxi-vfe/device/gc5004.ko
INSTALL drivers/media/video/sunxi-vfe/device/imx214.ko
INSTALL drivers/media/video/sunxi-vfe/device/imx322.ko
INSTALL drivers/media/video/sunxi-vfe/device/imx219.ko
INSTALL drivers/media/video/sunxi-vfe/device/ov12830.ko
INSTALL drivers/media/video/sunxi-vfe/device/imx224.ko
INSTALL drivers/media/video/sunxi-vfe/device/ov13850.ko
INSTALL drivers/media/video/sunxi-vfe/device/ov2710_mipi.ko
INSTALL drivers/media/video/sunxi-vfe/device/ov16825.ko
INSTALL drivers/media/video/sunxi-vfe/device/ov5640.ko
INSTALL drivers/media/video/sunxi-vfe/device/ov5647.ko
INSTALL drivers/media/video/sunxi-vfe/device/ov5648.ko
INSTALL drivers/media/video/sunxi-vfe/device/ov5650.ko
INSTALL drivers/media/video/sunxi-vfe/device/ov5647_mipi.ko
INSTALL drivers/media/video/sunxi-vfe/device/ov7736.ko
INSTALL drivers/media/video/sunxi-vfe/device/ov8825.ko
INSTALL drivers/media/video/sunxi-vfe/device/ov8858.ko
INSTALL drivers/media/video/sunxi-vfe/device/ov8858_4lane.ko
INSTALL drivers/media/video/sunxi-vfe/device/ov8850.ko
INSTALL drivers/media/video/sunxi-vfe/device/ov8858_r2a_4lane.ko
INSTALL drivers/media/video/sunxi-vfe/device/ov8865_4lane.ko
INSTALL drivers/media/video/sunxi-vfe/device/ps1210.ko
INSTALL drivers/media/video/sunxi-vfe/device/s5k4e1.ko
INSTALL drivers/media/video/sunxi-vfe/device/s5k4e1_mipi.ko
INSTALL drivers/media/video/sunxi-vfe/device/s5k4ec.ko
INSTALL drivers/media/video/sunxi-vfe/device/s5k4ec_mipi.ko
INSTALL drivers/media/video/sunxi-vfe/device/s5k5e2yx.ko
INSTALL drivers/media/video/sunxi-vfe/device/sp0718.ko
INSTALL drivers/media/video/sunxi-vfe/device/sp0838.ko
INSTALL drivers/media/video/sunxi-vfe/device/sp2518.ko
INSTALL drivers/media/video/sunxi-vfe/device/sp2519.ko
INSTALL drivers/media/video/sunxi-vfe/device/sp5408.ko
INSTALL drivers/media/video/sunxi-vfe/device/sp5409.ko
INSTALL drivers/media/video/sunxi-vfe/device/t8et5.ko
INSTALL drivers/media/video/sunxi-vfe/vfe_os.ko
INSTALL drivers/media/video/sunxi-vfe/vfe_subdev.ko
INSTALL drivers/media/video/tm6000/tm6000-alsa.ko
INSTALL drivers/media/video/tm6000/tm6000.ko
INSTALL drivers/media/video/sunxi-vfe/vfe_v4l2.ko
INSTALL drivers/media/video/tveeprom.ko
INSTALL drivers/media/video/tvp5150.ko
INSTALL drivers/media/video/tm6000/tm6000-dvb.ko
INSTALL drivers/media/video/tw9910.ko
INSTALL drivers/media/video/tuner.ko
INSTALL drivers/media/video/usbvision/usbvision.ko
INSTALL drivers/media/video/videobuf-dma-contig.ko
INSTALL drivers/media/video/uvc/uvcvideo.ko
INSTALL drivers/media/video/videobuf-core.ko
INSTALL drivers/media/video/videobuf2-core.ko
INSTALL drivers/media/video/videobuf-dvb.ko
INSTALL drivers/media/video/videobuf-vmalloc.ko
INSTALL drivers/media/video/videobuf2-memops.ko
INSTALL drivers/media/video/videobuf2-dma-contig.ko
INSTALL drivers/media/video/videobuf2-vmalloc.ko
INSTALL drivers/media/video/wm8775.ko
INSTALL drivers/mfd/wl1273-core.ko
INSTALL drivers/misc/eeprom/at24.ko
INSTALL drivers/misc/eeprom/eeprom_93cx6.ko
INSTALL drivers/media/video/zr364xx.ko
INSTALL drivers/net/bonding/bonding.ko
INSTALL drivers/net/can/c_can/c_can.ko
INSTALL drivers/net/can/can-dev.ko
INSTALL drivers/net/can/mcp251x.ko
INSTALL drivers/net/can/cc770/cc770.ko
INSTALL drivers/net/can/softing/softing.ko
INSTALL drivers/net/can/slcan.ko
INSTALL drivers/net/can/usb/ems_usb.ko
INSTALL drivers/net/can/sja1000/sja1000.ko
INSTALL drivers/net/can/usb/peak_usb/peak_usb.ko
INSTALL drivers/net/can/usb/esd_usb2.ko
INSTALL drivers/net/can/vcan.ko
INSTALL drivers/net/dummy.ko
INSTALL drivers/net/eql.ko
INSTALL drivers/net/irda/irtty-sir.ko
INSTALL drivers/net/irda/irda-usb.ko
INSTALL drivers/net/irda/kingsun-sir.ko
INSTALL drivers/net/irda/ks959-sir.ko
INSTALL drivers/net/irda/ksdazzle-sir.ko
INSTALL drivers/net/irda/mcs7780.ko
INSTALL drivers/net/irda/sir-dev.ko
INSTALL drivers/net/irda/stir4200.ko
INSTALL drivers/net/macvlan.ko
INSTALL drivers/net/macvtap.ko
INSTALL drivers/net/ppp/bsd_comp.ko
INSTALL drivers/net/phy/spi_ks8995.ko
INSTALL drivers/net/ppp/ppp_async.ko
INSTALL drivers/net/ppp/ppp_deflate.ko
INSTALL drivers/net/ppp/ppp_generic.ko
INSTALL drivers/net/ppp/ppp_synctty.ko
INSTALL drivers/net/ppp/ppp_mppe.ko
INSTALL drivers/net/ppp/pppolac.ko
INSTALL drivers/net/ppp/pppoe.ko
INSTALL drivers/net/ppp/pppox.ko
INSTALL drivers/net/ppp/pppopns.ko
INSTALL drivers/net/ppp/pptp.ko
INSTALL drivers/net/slip/slhc.ko
INSTALL drivers/net/usb/asix.ko
INSTALL drivers/net/slip/slip.ko
INSTALL drivers/net/usb/cdc_ether.ko
INSTALL drivers/net/tun.ko
INSTALL drivers/net/usb/cdc_ncm.ko
INSTALL drivers/net/usb/cdc_subset.ko
INSTALL drivers/net/usb/cx82310_eth.ko
INSTALL drivers/net/usb/dm9601.ko
INSTALL drivers/net/usb/gl620a.ko
INSTALL drivers/net/usb/int51x1.ko
INSTALL drivers/net/usb/hso.ko
INSTALL drivers/net/usb/ipheth.ko
INSTALL drivers/net/usb/kalmia.ko
INSTALL drivers/net/usb/kaweth.ko
INSTALL drivers/net/usb/lg-vl600.ko
INSTALL drivers/net/usb/net1080.ko
INSTALL drivers/net/usb/mcs7830.ko
INSTALL drivers/net/usb/pegasus.ko
INSTALL drivers/net/usb/rndis_host.ko
INSTALL drivers/net/usb/rtl8150.ko
INSTALL drivers/net/usb/qmi_wwan.ko
INSTALL drivers/net/usb/smsc75xx.ko
INSTALL drivers/net/usb/sierra_net.ko
INSTALL drivers/net/usb/zaurus.ko
INSTALL drivers/net/wan/dlci.ko
INSTALL drivers/net/veth.ko
INSTALL drivers/net/wan/hdlc_cisco.ko
INSTALL drivers/net/wan/hdlc.ko
INSTALL drivers/net/wan/hdlc_ppp.ko
INSTALL drivers/net/wan/hdlc_raw.ko
INSTALL drivers/net/wan/hdlc_fr.ko
INSTALL drivers/net/wan/hdlc_raw_eth.ko
INSTALL drivers/net/wireless/at76c50x-usb.ko
INSTALL drivers/net/wireless/ath/ath.ko
INSTALL drivers/net/wireless/ath/ath6kl/ath6kl_sdio.ko
INSTALL drivers/net/wireless/ath/ath6kl/ath6kl_core.ko
INSTALL drivers/net/wireless/ath/ath9k/ath9k_common.ko
INSTALL drivers/net/wireless/ath/ath9k/ath9k.ko
INSTALL drivers/net/wireless/ath/ath6kl/ath6kl_usb.ko
INSTALL drivers/net/wireless/ath/ath9k/ath9k_htc.ko
INSTALL drivers/net/wireless/ath/carl9170/carl9170.ko
INSTALL drivers/net/wireless/ath/ath9k/ath9k_hw.ko
INSTALL drivers/net/wireless/libertas_tf/libertas_tf.ko
INSTALL drivers/net/wireless/mac80211_hwsim.ko
INSTALL drivers/net/wireless/bcmdhd/bcmdhd.ko
INSTALL drivers/net/wireless/libertas_tf/libertas_tf_usb.ko
INSTALL drivers/net/wireless/rndis_wlan.ko
INSTALL drivers/net/wireless/rtl818x/rtl8187/rtl8187.ko
INSTALL drivers/parport/parport.ko
INSTALL drivers/net/wireless/zd1201.ko
INSTALL drivers/rtc/rtc-pcf8563.ko
INSTALL drivers/rtc/rtc-ds1307.ko
INSTALL drivers/scsi/ch.ko
INSTALL drivers/scsi/device_handler/scsi_dh.ko
INSTALL drivers/scsi/device_handler/scsi_dh_emc.ko
INSTALL drivers/scsi/device_handler/scsi_dh_hp_sw.ko
INSTALL drivers/scsi/device_handler/scsi_dh_rdac.ko
INSTALL drivers/scsi/osd/libosd.ko
INSTALL drivers/scsi/osd/osd.ko
INSTALL drivers/scsi/scsi_wait_scan.ko
INSTALL drivers/scsi/st.ko
INSTALL drivers/scsi/osst.ko
INSTALL drivers/tty/n_hdlc.ko
INSTALL drivers/tty/n_r3964.ko
INSTALL drivers/tty/n_tracesink.ko
INSTALL drivers/tty/n_tracerouter.ko
INSTALL drivers/usb/class/cdc-acm.ko
INSTALL drivers/usb/image/mdc800.ko
INSTALL drivers/usb/class/cdc-wdm.ko
INSTALL drivers/usb/image/microtek.ko
INSTALL drivers/usb/class/usblp.ko
INSTALL drivers/usb/misc/adutux.ko
INSTALL drivers/usb/misc/appledisplay.ko
INSTALL drivers/usb/misc/cypress_cy7c63.ko
INSTALL drivers/usb/misc/cytherm.ko
INSTALL drivers/usb/misc/emi26.ko
INSTALL drivers/usb/misc/emi62.ko
INSTALL drivers/usb/misc/ftdi-elan.ko
INSTALL drivers/usb/misc/idmouse.ko
INSTALL drivers/usb/misc/iowarrior.ko
INSTALL drivers/usb/misc/isight_firmware.ko
INSTALL drivers/usb/misc/ldusb.ko
INSTALL drivers/usb/misc/legousbtower.ko
INSTALL drivers/usb/misc/rio500.ko
INSTALL drivers/usb/misc/trancevibrator.ko
INSTALL drivers/usb/misc/usblcd.ko
INSTALL drivers/usb/misc/usbled.ko
INSTALL drivers/usb/misc/usbsevseg.ko
INSTALL drivers/usb/misc/usbtest.ko
INSTALL drivers/usb/serial/aircable.ko
INSTALL drivers/usb/misc/yurex.ko
INSTALL drivers/usb/serial/belkin_sa.ko
INSTALL drivers/usb/serial/ark3116.ko
INSTALL drivers/usb/serial/ch341.ko
INSTALL drivers/usb/serial/cp210x.ko
INSTALL drivers/usb/serial/cyberjack.ko
INSTALL drivers/usb/serial/cypress_m8.ko
INSTALL drivers/usb/serial/digi_acceleport.ko
INSTALL drivers/usb/serial/garmin_gps.ko
INSTALL drivers/usb/serial/ftdi_sio.ko
INSTALL drivers/usb/serial/empeg.ko
INSTALL drivers/usb/serial/f81232.ko
INSTALL drivers/usb/serial/io_edgeport.ko
INSTALL drivers/usb/serial/ipaq.ko
INSTALL drivers/usb/serial/io_ti.ko
INSTALL drivers/usb/serial/ipw.ko
INSTALL drivers/usb/serial/ir-usb.ko
INSTALL drivers/usb/serial/iuu_phoenix.ko
INSTALL drivers/usb/serial/keyspan_pda.ko
INSTALL drivers/usb/serial/keyspan.ko
INSTALL drivers/usb/serial/kl5kusb105.ko
INSTALL drivers/usb/serial/mct_u232.ko
INSTALL drivers/usb/serial/mos7840.ko
INSTALL drivers/usb/serial/metro-usb.ko
INSTALL drivers/usb/serial/mos7720.ko
INSTALL drivers/usb/serial/kobil_sct.ko
INSTALL drivers/usb/serial/omninet.ko
INSTALL drivers/usb/serial/opticon.ko
INSTALL drivers/usb/serial/navman.ko
INSTALL drivers/usb/serial/option.ko
INSTALL drivers/usb/serial/oti6858.ko
INSTALL drivers/usb/serial/pl2303.ko
INSTALL drivers/usb/serial/qcaux.ko
INSTALL drivers/usb/serial/qcserial.ko
INSTALL drivers/usb/serial/safe_serial.ko
INSTALL drivers/usb/serial/sierra.ko
INSTALL drivers/usb/serial/spcp8x5.ko
INSTALL drivers/usb/serial/ssu100.ko
INSTALL drivers/usb/serial/symbolserial.ko
INSTALL drivers/usb/serial/ti_usb_3410_5052.ko
INSTALL drivers/usb/serial/usb_wwan.ko
INSTALL drivers/usb/serial/usb_debug.ko
INSTALL drivers/usb/serial/visor.ko
INSTALL drivers/usb/serial/whiteheat.ko
INSTALL drivers/video/fbtft/fb_bd663474.ko
INSTALL drivers/video/fbtft/fb_hx8340bn.ko
INSTALL drivers/video/backlight/lcd.ko
INSTALL drivers/video/fbtft/fb_hx8347d.ko
INSTALL drivers/video/fbtft/fb_hx8353d.ko
INSTALL drivers/video/fbtft/fb_ili9320.ko
INSTALL drivers/video/fbtft/fb_ili9325.ko
INSTALL drivers/video/fbtft/fb_ili9340.ko
INSTALL drivers/video/fbtft/fb_ra8875.ko
INSTALL drivers/video/fbtft/fb_ili9486.ko
INSTALL drivers/video/fbtft/fb_ili9341.ko
INSTALL drivers/video/fbtft/fb_s6d02a1.ko
INSTALL drivers/video/fbtft/fb_ssd1306.ko
INSTALL drivers/video/fbtft/fb_ssd1331.ko
INSTALL drivers/video/fbtft/fb_pcd8544.ko
INSTALL drivers/video/fbtft/fb_ssd1289.ko
INSTALL drivers/video/fbtft/fb_s6d1121.ko
INSTALL drivers/video/fbtft/fb_ssd1351.ko
INSTALL drivers/video/fbtft/fb_st7735r.ko
INSTALL drivers/video/fbtft/fb_tls8204.ko
INSTALL drivers/video/fbtft/fb_tinylcd.ko
INSTALL drivers/video/fbtft/fb_upd161704.ko
INSTALL drivers/video/fbtft/fb_watterott.ko
INSTALL drivers/video/fbtft/fbtft.ko
INSTALL drivers/video/fbtft/fbtft_device.ko
INSTALL drivers/video/fbtft/flexfb.ko
INSTALL drivers/w1/w1_sunxi.ko
INSTALL lib/crc7.ko
INSTALL lib/raid6/raid6_pq.ko
INSTALL lib/ts_bm.ko
INSTALL lib/ts_fsm.ko
INSTALL lib/ts_kmp.ko
INSTALL net/802/garp.ko
INSTALL net/802/psnap.ko
INSTALL net/802/p8022.ko
INSTALL net/batman-adv/batman-adv.ko
INSTALL net/bridge/bridge.ko
INSTALL net/8021q/8021q.ko
INSTALL net/802/stp.ko
INSTALL net/bridge/netfilter/ebt_802_3.ko
INSTALL net/bridge/netfilter/ebt_among.ko
INSTALL net/bridge/netfilter/ebt_arp.ko
INSTALL net/bridge/netfilter/ebt_dnat.ko
INSTALL net/bridge/netfilter/ebt_arpreply.ko
INSTALL net/bridge/netfilter/ebt_ip.ko
INSTALL net/bridge/netfilter/ebt_mark.ko
INSTALL net/bridge/netfilter/ebt_log.ko
INSTALL net/bridge/netfilter/ebt_limit.ko
INSTALL net/bridge/netfilter/ebt_ip6.ko
INSTALL net/bridge/netfilter/ebt_mark_m.ko
INSTALL net/bridge/netfilter/ebt_nflog.ko
INSTALL net/bridge/netfilter/ebt_redirect.ko
INSTALL net/bridge/netfilter/ebt_pkttype.ko
INSTALL net/bridge/netfilter/ebt_snat.ko
INSTALL net/bridge/netfilter/ebt_ulog.ko
INSTALL net/bridge/netfilter/ebtable_broute.ko
INSTALL net/bridge/netfilter/ebt_vlan.ko
INSTALL net/bridge/netfilter/ebt_stp.ko
INSTALL net/bridge/netfilter/ebtable_nat.ko
INSTALL net/bridge/netfilter/ebtables.ko
INSTALL net/bridge/netfilter/ebtable_filter.ko
INSTALL net/can/can-gw.ko
INSTALL net/can/can-raw.ko
INSTALL net/can/can-bcm.ko
INSTALL net/core/netprio_cgroup.ko
INSTALL net/can/can.ko
INSTALL net/ipv4/gre.ko
INSTALL net/ipv4/ip_gre.ko
INSTALL net/ipv4/inet_diag.ko
INSTALL net/ipv4/netfilter/arpt_mangle.ko
INSTALL net/core/pktgen.ko
INSTALL net/ipv4/netfilter/arptable_filter.ko
INSTALL net/ipv4/netfilter/arp_tables.ko
INSTALL net/ipv4/netfilter/ip_queue.ko
INSTALL net/ipv4/netfilter/ip_tables.ko
INSTALL net/ipv4/netfilter/ipt_ECN.ko
INSTALL net/ipv4/netfilter/ipt_MASQUERADE.ko
INSTALL net/ipv4/netfilter/ipt_CLUSTERIP.ko
INSTALL net/ipv4/netfilter/ipt_NETMAP.ko
INSTALL net/ipv4/netfilter/ipt_REDIRECT.ko
INSTALL net/ipv4/netfilter/ipt_REJECT.ko
INSTALL net/ipv4/netfilter/ipt_ah.ko
INSTALL net/ipv4/netfilter/ipt_rpfilter.ko
INSTALL net/ipv4/netfilter/iptable_filter.ko
INSTALL net/ipv4/netfilter/iptable_mangle.ko
INSTALL net/ipv4/netfilter/iptable_nat.ko
INSTALL net/ipv4/netfilter/iptable_raw.ko
INSTALL net/ipv4/netfilter/nf_conntrack_ipv4.ko
INSTALL net/ipv4/netfilter/nf_defrag_ipv4.ko
INSTALL net/ipv4/netfilter/nf_nat.ko
INSTALL net/ipv4/netfilter/nf_nat_amanda.ko
INSTALL net/ipv4/netfilter/nf_nat_h323.ko
INSTALL net/ipv4/netfilter/nf_nat_ftp.ko
INSTALL net/ipv4/netfilter/nf_nat_pptp.ko
INSTALL net/ipv4/netfilter/nf_nat_irc.ko
INSTALL net/ipv4/netfilter/nf_nat_proto_dccp.ko
INSTALL net/ipv4/netfilter/nf_nat_proto_sctp.ko
INSTALL net/ipv4/netfilter/nf_nat_proto_udplite.ko
INSTALL net/ipv4/netfilter/nf_nat_proto_gre.ko
INSTALL net/ipv4/netfilter/nf_nat_sip.ko
INSTALL net/ipv4/netfilter/nf_nat_snmp_basic.ko
INSTALL net/ipv4/netfilter/nf_nat_tftp.ko
INSTALL net/ipv4/tcp_bic.ko
INSTALL net/ipv4/tcp_diag.ko
INSTALL net/ipv4/tcp_htcp.ko
INSTALL net/ipv4/tcp_westwood.ko
INSTALL net/ipv6/ah6.ko
INSTALL net/ipv6/esp6.ko
INSTALL net/ipv6/ipcomp6.ko
INSTALL net/ipv6/ip6_tunnel.ko
INSTALL net/ipv6/netfilter/ip6_queue.ko
INSTALL net/ipv4/udp_diag.ko
INSTALL net/ipv6/netfilter/ip6_tables.ko
INSTALL net/ipv6/mip6.ko
INSTALL net/ipv6/netfilter/ip6t_eui64.ko
INSTALL net/ipv6/netfilter/ip6t_ah.ko
INSTALL net/ipv6/netfilter/ip6t_REJECT.ko
INSTALL net/ipv6/netfilter/ip6t_hbh.ko
INSTALL net/ipv6/netfilter/ip6t_frag.ko
INSTALL net/ipv6/netfilter/ip6t_rpfilter.ko
INSTALL net/ipv6/netfilter/ip6t_mh.ko
INSTALL net/ipv6/netfilter/ip6t_rt.ko
INSTALL net/ipv6/netfilter/ip6table_mangle.ko
INSTALL net/ipv6/netfilter/ip6t_ipv6header.ko
INSTALL net/ipv6/netfilter/ip6table_filter.ko
INSTALL net/ipv6/netfilter/ip6table_raw.ko
INSTALL net/ipv6/tunnel6.ko
INSTALL net/ipv6/netfilter/nf_defrag_ipv6.ko
INSTALL net/ipv6/netfilter/nf_conntrack_ipv6.ko
INSTALL net/ipv6/xfrm6_mode_beet.ko
INSTALL net/ipv6/xfrm6_mode_transport.ko
INSTALL net/ipv6/xfrm6_mode_tunnel.ko
INSTALL net/ipv6/xfrm6_tunnel.ko
INSTALL net/ipv6/xfrm6_mode_ro.ko
INSTALL net/irda/irda.ko
INSTALL net/irda/ircomm/ircomm-tty.ko
INSTALL net/irda/ircomm/ircomm.ko
INSTALL net/irda/irlan/irlan.ko
INSTALL net/irda/irnet/irnet.ko
INSTALL net/l2tp/l2tp_core.ko
INSTALL net/l2tp/l2tp_eth.ko
INSTALL net/l2tp/l2tp_ip.ko
INSTALL net/l2tp/l2tp_netlink.ko
INSTALL net/l2tp/l2tp_ppp.ko
INSTALL net/llc/llc.ko
INSTALL net/netfilter/ipset/ip_set_bitmap_port.ko
INSTALL net/netfilter/ipset/ip_set_bitmap_ip.ko
INSTALL net/netfilter/ipset/ip_set.ko
INSTALL net/netfilter/ipset/ip_set_bitmap_ipmac.ko
INSTALL net/netfilter/ipset/ip_set_hash_ip.ko
INSTALL net/netfilter/ipset/ip_set_hash_ipport.ko
INSTALL net/netfilter/ipset/ip_set_hash_ipportnet.ko
INSTALL net/netfilter/ipset/ip_set_hash_ipportip.ko
INSTALL net/netfilter/ipset/ip_set_hash_net.ko
INSTALL net/netfilter/ipset/ip_set_hash_netiface.ko
INSTALL net/netfilter/ipset/ip_set_list_set.ko
INSTALL net/netfilter/ipvs/ip_vs.ko
INSTALL net/netfilter/ipvs/ip_vs_dh.ko
INSTALL net/netfilter/ipvs/ip_vs_ftp.ko
INSTALL net/netfilter/ipset/ip_set_hash_netport.ko
INSTALL net/netfilter/ipvs/ip_vs_lblc.ko
INSTALL net/netfilter/ipvs/ip_vs_lblcr.ko
INSTALL net/netfilter/ipvs/ip_vs_lc.ko
INSTALL net/netfilter/ipvs/ip_vs_nq.ko
INSTALL net/netfilter/ipvs/ip_vs_pe_sip.ko
INSTALL net/netfilter/ipvs/ip_vs_rr.ko
INSTALL net/netfilter/ipvs/ip_vs_wlc.ko
INSTALL net/netfilter/ipvs/ip_vs_wrr.ko
INSTALL net/netfilter/ipvs/ip_vs_sed.ko
INSTALL net/netfilter/nf_conntrack.ko
INSTALL net/netfilter/ipvs/ip_vs_sh.ko
INSTALL net/netfilter/nf_conntrack_amanda.ko
INSTALL net/netfilter/nf_conntrack_broadcast.ko
INSTALL net/netfilter/nf_conntrack_ftp.ko
INSTALL net/netfilter/nf_conntrack_h323.ko
INSTALL net/netfilter/nf_conntrack_irc.ko
INSTALL net/netfilter/nf_conntrack_netbios_ns.ko
INSTALL net/netfilter/nf_conntrack_pptp.ko
INSTALL net/netfilter/nf_conntrack_proto_dccp.ko
INSTALL net/netfilter/nf_conntrack_netlink.ko
INSTALL net/netfilter/nf_conntrack_proto_gre.ko
INSTALL net/netfilter/nf_conntrack_proto_sctp.ko
INSTALL net/netfilter/nf_conntrack_proto_udplite.ko
INSTALL net/netfilter/nf_conntrack_sane.ko
INSTALL net/netfilter/nf_conntrack_snmp.ko
INSTALL net/netfilter/nf_conntrack_sip.ko
INSTALL net/netfilter/nf_conntrack_tftp.ko
INSTALL net/netfilter/nf_tproxy_core.ko
INSTALL net/netfilter/nfnetlink_acct.ko
INSTALL net/netfilter/nfnetlink_queue.ko
INSTALL net/netfilter/nfnetlink_log.ko
INSTALL net/netfilter/nfnetlink.ko
INSTALL net/netfilter/nfnetlink_cttimeout.ko
INSTALL net/netfilter/xt_CHECKSUM.ko
INSTALL net/netfilter/xt_CLASSIFY.ko
INSTALL net/netfilter/x_tables.ko
INSTALL net/netfilter/xt_CONNSECMARK.ko
INSTALL net/netfilter/xt_CT.ko
INSTALL net/netfilter/xt_DSCP.ko
INSTALL net/netfilter/xt_IDLETIMER.ko
INSTALL net/netfilter/xt_LED.ko
INSTALL net/netfilter/xt_HL.ko
INSTALL net/netfilter/xt_LOG.ko
INSTALL net/netfilter/xt_NFQUEUE.ko
INSTALL net/netfilter/xt_NFLOG.ko
INSTALL net/netfilter/xt_NOTRACK.ko
INSTALL net/netfilter/xt_RATEEST.ko
INSTALL net/netfilter/xt_SECMARK.ko
INSTALL net/netfilter/xt_TCPMSS.ko
INSTALL net/netfilter/xt_TCPOPTSTRIP.ko
INSTALL net/netfilter/xt_TEE.ko
INSTALL net/netfilter/xt_TPROXY.ko
INSTALL net/netfilter/xt_TRACE.ko
INSTALL net/netfilter/xt_cluster.ko
INSTALL net/netfilter/xt_addrtype.ko
INSTALL net/netfilter/xt_comment.ko
INSTALL net/netfilter/xt_connlimit.ko
INSTALL net/netfilter/xt_connmark.ko
INSTALL net/netfilter/xt_connbytes.ko
INSTALL net/netfilter/xt_conntrack.ko
INSTALL net/netfilter/xt_cpu.ko
INSTALL net/netfilter/xt_dscp.ko
INSTALL net/netfilter/xt_devgroup.ko
INSTALL net/netfilter/xt_dccp.ko
INSTALL net/netfilter/xt_ecn.ko
INSTALL net/netfilter/xt_esp.ko
INSTALL net/netfilter/xt_helper.ko
INSTALL net/netfilter/xt_hashlimit.ko
INSTALL net/netfilter/xt_hl.ko
INSTALL net/netfilter/xt_iprange.ko
INSTALL net/netfilter/xt_length.ko
INSTALL net/netfilter/xt_ipvs.ko
INSTALL net/netfilter/xt_mark.ko
INSTALL net/netfilter/xt_limit.ko
INSTALL net/netfilter/xt_mac.ko
INSTALL net/netfilter/xt_multiport.ko
INSTALL net/netfilter/xt_nfacct.ko
INSTALL net/netfilter/xt_osf.ko
INSTALL net/netfilter/xt_owner.ko
INSTALL net/netfilter/xt_physdev.ko
INSTALL net/netfilter/xt_pkttype.ko
INSTALL net/netfilter/xt_policy.ko
INSTALL net/netfilter/xt_quota.ko
INSTALL net/netfilter/xt_realm.ko
INSTALL net/netfilter/xt_rateest.ko
INSTALL net/netfilter/xt_sctp.ko
INSTALL net/netfilter/xt_recent.ko
INSTALL net/netfilter/xt_set.ko
INSTALL net/netfilter/xt_socket.ko
INSTALL net/netfilter/xt_statistic.ko
INSTALL net/netfilter/xt_tcpmss.ko
INSTALL net/netfilter/xt_state.ko
INSTALL net/netfilter/xt_string.ko
INSTALL net/netfilter/xt_time.ko
INSTALL net/netfilter/xt_tcpudp.ko
INSTALL net/sctp/sctp.ko
INSTALL net/netfilter/xt_u32.ko
INSTALL net/openvswitch/openvswitch.ko
INSTALL output/lib/firmware/emi26/loader.fw
INSTALL output/lib/firmware/emi26/firmware.fw
INSTALL output/lib/firmware/emi26/bitstream.fw
INSTALL output/lib/firmware/emi62/loader.fw
INSTALL output/lib/firmware/emi62/bitstream.fw
INSTALL output/lib/firmware/emi62/spdif.fw
INSTALL output/lib/firmware/emi62/midi.fw
INSTALL output/lib/firmware/kaweth/new_code.bin
INSTALL output/lib/firmware/kaweth/trigger_code.bin
INSTALL output/lib/firmware/kaweth/new_code_fix.bin
INSTALL output/lib/firmware/ti_3410.fw
INSTALL output/lib/firmware/kaweth/trigger_code_fix.bin
INSTALL output/lib/firmware/ti_5052.fw
INSTALL output/lib/firmware/mts_cdma.fw
INSTALL output/lib/firmware/mts_edge.fw
INSTALL output/lib/firmware/mts_gsm.fw
MKDIR output/lib/firmware/edgeport/
INSTALL output/lib/firmware/whiteheat.fw
INSTALL output/lib/firmware/whiteheat_loader.fw
MKDIR output/lib/firmware/keyspan_pda/
MKDIR output/lib/firmware/cpia2/
INSTALL output/lib/firmware/edgeport/boot.fw
INSTALL output/lib/firmware/edgeport/boot2.fw
INSTALL output/lib/firmware/edgeport/down2.fw
INSTALL output/lib/firmware/edgeport/down.fw
INSTALL output/lib/firmware/edgeport/down3.bin
INSTALL output/lib/firmware/keyspan_pda/keyspan_pda.fw
INSTALL output/lib/firmware/keyspan_pda/xircom_pgs.fw
INSTALL output/lib/firmware/cpia2/stv0672_vp4.bin
DEPMOD 3.4.39-BPI-M3-Kernel
make -C linux-sunxi ARCH=arm CROSS_COMPILE=/usr/bin/arm-linux-gnueabihf- -j16 headers_install
HOSTCC scripts/unifdef
INSTALL include (0 file)
INSTALL include/asm-generic (34 files)
INSTALL include/drm (15 files)
INSTALL include/linux (1 file)
INSTALL include/video (3 files)
INSTALL include/sound (10 files)
INSTALL include/xen (2 files)
INSTALL include/scsi (3 files)
INSTALL include/mtd (5 files)
INSTALL include/rdma (6 files)
INSTALL include/scsi/fc (4 files)
INSTALL include/asm (32 files)
cd linux-sunxi && /usr/bin/arm-linux-gnueabihf-objcopy -R .note.gnu.build-id -S -O binary vmlinux bImage
Build success!
[email protected]:/home/pi/emmc/BPI-M3-bsp# cp linux-sunxi/arch/arm/boot/uImage /boot/bananapi/bpi-m3/linux
[email protected]:/home/pi/emmc/BPI-M3-bsp# reboot
