一星期前,淘到块32*64 RGB点阵显示屏,回来,马上接stm32试了下,没有坏点。全部点亮,是1/16扫描,也就是说是标准接口
接口特写:
0x02:驱动得益于强大的树莓派社区,发现个rgb点阵项目。直接拿来用不错:https://github.com/hzeller/rpi-rgb-led-matrix
项目是支持RPI B / B+ / 2B 的,所以提供了3种接线方法。实际我接线是采用 “[1]” 的接线方法只用到前26个gpio 为嘛不采用2 或3的接线方法呢,是因为我没有40pin的PI ,只有个B 。0x03:运行 下载:wget https://github.com/hzeller/rpi-rgb-led-matrix/archive/master.zip 解压缩:
unzip master.zipcd rpi-rgb-led-matrix-master/
编译:
make
运行:
./led-matrix
会弹出如下提示:
usage: ./led-matrix <options> -D <demo-nr> [optional parameter]Options:
-r <rows> : Display rows. 16 for 16x32, 32 for 32x32. Default: 32
-c <chained> : Daisy-chained boards. Default: 1.
-L : 'Large' display, composed out of 4 times 32x32
-p <pwm-bits> : Bits used for PWM. Something between 1..7
-g : Do gamma correction (experimental)
-D <demo-nr> : Always needs to be set
-d : run as daemon. Use this when starting in
/etc/init.d, but also when running without
terminal (e.g. cron).
-t <seconds> : Run for these number of seconds, then exit.
(if neither -d nor -t are supplied, waits for <RETURN>)
Demos, choosen with -D
0 - some rotating square
1 - forward scrolling an image (-m <scroll-ms>)
2 - backward scrolling an image (-m <scroll-ms>)
3 - test image: a square
4 - Pulsing color
Example:
./led-matrix -t 10 -D 1 runtext.ppm
Scrolls the runtext for 10 seconds
运行测试demo:
sudo ./led-matrix -d -r 32 -c 2 -t 20 -D 1 runtext.ppm #-d 会后台运行,-t 运行时间 -r 32 -c 2 指定是32*64点阵显示
之后嘿嘿就可以看到rgb 点阵屏上显示信息:(滚动显示ppm图片内容,懒得弄gif 了假装图片会动)
显示字符demo:
(while :; do date +%T ; sleep 0.5 ; done) | sudo ./text-example -f fonts/8x13B.bdf -y8 -c2 -C 255,255,255<p style="line-height: 28px;"></p>
实际上更有意思的是显示图片玩
sudo aptitude install libgraphicsmagick++-dev libwebp-dev
显示图片:
sudo ./led-image-viewer myimage.gif
效果嘛如下:
