BPI-R2 新镜像 :ubuntu-16.04-mate-desktop-docker-preview2-bpi-r2-10170801
2017-08-01-ubuntu-16.04-mate-desktop-docker-preview2-bpi-r2-sd-emmc.img.zip
0. based on ubuntu 16.04.2 LTS Mate Desktop
  1. support BPI-R2 kernel 4.4.70
  2. username & password: pi/bananapi , root/bananapi
  3. support HDMI
  4. support GMAC * 5 (2 real GE ports, 1 is WAN port, another is connected to 4 LAN ports)
  5. support SATA * 2
  6. support eMMC (support boot from eMMC)
  7. support IR
  8. support OTG
  9. support PWM (PWM1/PWM2/PWM3, PWM4 and PWM5 are not supported)
  10. support USB 3.0 * 2
  11. support mPCIe
  12. support uEnv.txt to fatload uImage
  13. support bpi-bootsel
  14. support bpi-copy to write SD/eMMC with img.zip file
  15. support docker
  16. ref. https://github.com/BPI-SINOVOIP/BPI-R2-bsp
  17. ref. https://github.com/BPI-SINOVOIP/BPI-files
How to boot from eMMC:
  1. boot from SD
  2. sudo su
  3. echo 0 > /sys/block/mmcblk1boot0/force_ro #enable /dev/mmcblk1boot0 write mode
  4. bpi-bootsel BPI-R2-EMMC-boot0-0k.img.gz /dev/mmcblk1boot0 #write once
  5. bpi-copy /path_to_your_image/xxx.img.zip
  6. poweroff
  7. remove SD & power on
Known limitations:
  1. WIFI/BT isn’t supported
  2. MIPI interface doesn’t work
Google Drive:
https://drive.google.com/file/d/0B_YnvHgh2rwjS1Z1OFRRZlpQNDg/view?usp=sharing
baidu cloud:
http://pan.baidu.com/s/1bpElcf1
MD5: 021e2e5a627f9e60742c6bbb6b4e8dc8
FILESIZE: 1774241037 (~1692MB)
UNPACK: 7456MB (eMMC size)
请问一下我下载了 2017-08-01-ubuntu-16.04-mate-desktop-preview2-bpi-r2-sd-emmc.img 并 dd 到了 SD 卡,插上后按电源按钮,只有 rgb 三个灯会在电源按下时亮,松开就灭,其它的都没有反应,通过 HDMI 插着的显示器也没有显示,是我哪里需要注意的我没有注意到么?
[quote=“sutra”, post: 2, topic: 2130]
sutra 发表于 2017-8-13 14:41
请问一下我下载了 2017-08-01-ubuntu-16.04-mate-desktop-preview2-bpi-r2-sd-emmc.img 并 dd 到了 SD 卡, …
我终于能开机进入到 ubuntu MATE 的图形桌面了。
折腾了一通,折腾方法如下,我根据 https://bananapi.gitbooks.io/banana-pi-bpi-r2-open-source-smart-router/content/bpi-r2-quick-start.html 这里说的没有找到开机方法,只找到关机方法:
“After that you can press the power key for 5 seconds to turn it off.”
看到说要按电源键5秒来关机,我就试着按电源键5秒来开机,然后终于了有了不同的反应,HDMI接口和电源接口之间的三个灯中的,绿灯闪呀闪,然后中间的红灯常亮,等了很久 HDMI 显示器依旧没有显示,我按 reset 按钮按了几次,它似乎重启了几次,然后我终于看到了 Linux 启动的信息,并最后进入了 GUI 了。
