BPI-R2 new Image :2017-09-04-ubuntu-16.04-mate-desktop-bpi-r2-sd-emmc-v1.2.0.img.zip
WIFI working fine and boot from eMMC flash.
V1.2 Release notes
About this release
This release is for banana pi R2 board which is based on MTK7623N, and it just includes Ubuntu image which is based on Ubuntu 16.04.2 LTS Mate Desktop with Linux kernel 4.4.70, we can get the Linux kernel 4.4.70 from the link https://github.com/BPI-SINOVOIP/BPI-R2-bsp.
The file system is based on Ubuntu 16.04.2 LTS Mate Desktop, the default user name/password are pi/bananapi , root/bananapi.
What’s new in this release
Support HDMI audio
Support onboard WIFI module(MT6625), The wifi interface is enabled by default in latest image which is released by banana-pi please use command “echo 0>/dev/wmtWifi” to turn it off and use the command “echo 1>/dev/wmtWifi” to enable it.
Enable EMMC
Change the DDR frequency from 1.3GHZ to 1.6GHZ
Both PWM4 and PWM5 work
Add the utility iperf to this image
Known limitations
BT isn’t supported
MIPI interface doesn’t work
Sometimes Linux kernel 4.4.70 can’t boot successfully
Somtimes HDMI doesn’t work fine
AP mode isn’t supported yet
Image link:
Google drive: https://drive.google.com/file/d/0B_YnvHgh2rwjNUFiY0F2aURxY00/view?usp=sharing
Baidu drive: http://pan.baidu.com/s/1jH4pl5c
md5sum: 8c554bfe1f2e84c74fc60aef298282fa
