BPI-R2 new image : ubuntu 16.04 V1.2.1 Release: BT and WIFI AP mode are working fine
V1.2.1 Release notes
About this release
This release is for banana pi R2 board which is based on MTK7623N, and it just includes Ubuntu image which is based on Ubuntu 16.04.2 LTS Mate Desktop with Linux kernel 4.4.70, we can get the Linux kernel 4.4.70 and u-boot from the link https://github.com/BPI-SINOVOIP/BPI-R2-bsp
The file system is based on Ubuntu 16.04.2 LTS Mate Desktop, the default user name/password are pi/bananapi , root/bananapi. -
What’s new in this release
- Support AP mode of onboard WIFI module(MT6625)
- On board BT is supported
- Fix an ethernet issue in u-boot
- Add a command in u-boot to set partition configuration of EMMC
Known limitations
- MIPI interface doesn’t work
- Somtimes HDMI doesn’t work fine
Image link:
Google drive: https://drive.google.com/file/d/1KvVln42OTXeNUOpendfMgKMFNhBmIR60/view?usp=sharing
Baidu drive: 2017-11-28-ubuntu-16.04-mate-desktop-bpi-r2-sd-emmc.img.zip_免费高速下载|百度网盘-分享无限制
md5sum: b8f4b305f0301d121971ab575c65bb0f
FAQ
How to enable AP mode
Please refer to link: http://forum.banana-pi.org/t/2-4ghz-and-5-6ghz-wifi-working-fine/3844/32 -
How to enable BT
Please use command: hciconfig hci0 up to enable it -
How to program Ubuntu image to EMMC
a. Program ubuntu image to SD card
b. Install this SD to R2 board and boot from SD
c. Enter the Uboot prompt, and run command emmc pconf 48 to change Partition config of EMMC
d. And then run command reset, let it boot to OS
e. Enter the system with username pi or root
f. Run command
echo 0 > /sys/block/mmcblk1boot0/force_ro to enable /dev/mmcblk1boot0 write mode`g. To write preloader to EMMC by running command:
bpi-bootsel BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz /dev/mmcblk1boot0where BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz is the preloader for emmc, please download it from link https://github.com/BPI-SINOVOIP/BPI-files/blob/master/SD/100MB/BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz
h. To copy ubuntu image to EMMC:
unzip -p <XXX.img.zip> | pv | dd of=<device> bs=10M status=noxferorbpi-copy <XXX.img.zip> <device>where the XXX.img.zip is ubuntu image we can get it from http://www.banana-pi.org/r2-download.html, and where should be /dev/mmcblk1.
i. power off
j, remove SD & power on
How to control GPIO
Please refer to link: https://github.com/BPI-SINOVOIP/BPI-R2-bsp/issues/11#issuecomment-326988062
