BPI-M3-bsp
Getting Started
Choose a board doing: ./build.sh,
“This tool supports the following BPI board(s):”
BPI_M3_720P"
BPI_M3_1080P"
BPI_M3_LCD7"
BPI_M3_USB_720P"
BPI_M3_USB_1080P"
BPI-M3 SD Card Info
Step 1.To be on safe side erase the first part of your SD Card (also clears the partition table).
sudo dd if=/dev/zero of=${card} bs=1M count=1
Step 2.Go to folder “Download”, put the file(s) to 100MB of the SD Card whit DD command.
sudo dd if=boot0_sdcard.fex of=${card} bs=1k seek=8
sudo dd if=u-boot.fex of=${card} bs=1k seek=19096
sudo dd if=sunxi_mbr.fex of=${card} bs=1k seek=20480
sudo dd if=bootloader.fex of=${card} bs=1k seek=36864
sudo dd if=env.fex of=${card} bs=1k seek=69632
sudo dd if=boot.fex of=${card} bs=1k seek=86016
Overview
You may go to http://www.banana-pi.org to download Ubuntu15.04 images and burn them into the Sdcard to see the architecture.
