BPI-uno32-Webuino是BPI基于Webuino思想推出的可供Arduino用户平滑过渡的一块更高性能的开发板,板载ESP-WROOM-32模块,具体数据为:
ESP-WROOM-32
448KB ROM
520KB RAM
Wi-Fi & BLE
超低功耗
超高主频
支持超多通信协议
Github地址:https://github.com/yelvlab/BPI-UNO32
惯例:IDE环境 PlatformIO+VSCode
代码:
//uno32 NEW
//BPI - uno32 test code
#include <Arduino.h>
#include "WiFi.h"
#define LEDC_CHANNEL_0 0
#define LEDC_TIMER_13_BIT 13
#define LEDC_BASE_FREQ 450
#define Buzzer 25
const char *ssid = "SSID";
const char *password = "PASSWD";
const uint16_t PixelCount = 25;
const uint8_t PixelPin = 4;
#define colorSaturation 255
#define delay_ms 500
#define bout 3
#define LEDC_CHANNEL_1 1
#define LEDC_CHANNEL_2 2
#define LEDC_CHANNEL_3 3
#define LEDC_LED_FREQ 10000
#define LEDR 17
#define LEDG 16
#define LEDB 27
#define AD10 36 //ADC1_CH0
#define AD13 39 //ADC1_CH3
#define AD14 32 //ADC1_CH4
#define AD15 33 //ADC1_CH5
#define AD16 34 //ADC1_CH6
#define AD17 35 //ADC1_CH7
int AD_Value0 = 0;
int AD_Value3 = 0;
int AD_Value4 = 0;
int AD_Value5 = 0;
int AD_Value6 = 0;
int AD_Value7 = 0;
int adTestFreq = 0;
int wifiTestFreq = 0;
int ledTestFreq = 0;
int buzzerTestFreq = 0;
int brightness = 0;
int fadeAmount = 5;
void ledcAnalogWrite(uint8_t channel, uint32_t value)
// calculate duty, 8191 from 2 ^ 13 - 1 (2 ^ LEDC_TIMER_13_BIT - 1)
//value_MAX = 255
uint32_t duty = (8191 / 255) * value;
// write duty to LEDC
ledcWrite(channel, duty);
void setup()
Serial.begin(115200); //Serial Port Config 115200-8-N-1
while (!Serial)
; // wait for serial attach
Serial.println();
Serial.println("Initializing...");
Serial.flush();
Serial.println();
Serial.println("BPI-uno32 Function Test Demo");
Serial.println("Running...");
Serial.println();
ledcSetup(LEDC_CHANNEL_0, LEDC_BASE_FREQ, LEDC_TIMER_13_BIT);
ledcSetup(LEDC_CHANNEL_1, LEDC_LED_FREQ, LEDC_TIMER_13_BIT);
ledcSetup(LEDC_CHANNEL_2, LEDC_LED_FREQ, LEDC_TIMER_13_BIT);
ledcSetup(LEDC_CHANNEL_3, LEDC_LED_FREQ, LEDC_TIMER_13_BIT);
ledcAttachPin(Buzzer, LEDC_CHANNEL_0);
ledcAttachPin(LEDR, LEDC_CHANNEL_1);
ledcAttachPin(LEDG, LEDC_CHANNEL_2);
ledcAttachPin(LEDB, LEDC_CHANNEL_3);
void loop()
***Board:BPI:uno32-Webduino ***
***Function:RGB_LED Test ***
Serial.println();
Serial.println("LED test!!!");
Serial.println();
//LED_R fading
Serial.println("LED_R is fading");
for (ledTestFreq = 0; ledTestFreq < bout; ledTestFreq++)
for (brightness = 0; brightness < 255; brightness++)
Serial.print(".");
// set the brightness on LEDC channel 0
ledcAnalogWrite(LEDC_CHANNEL_1, brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness <= 0 || brightness >= 255)
fadeAmount = -fadeAmount;
// wait for 30 milliseconds to see the dimming effect
delay(30);
Serial.println();
ledcAnalogWrite(LEDC_CHANNEL_1, 0);
//LED_G fading
Serial.println("LED_G is fading");
Serial.print(".");
ledcAnalogWrite(LEDC_CHANNEL_2, brightness);
delay(30);
Serial.println();
ledcAnalogWrite(LEDC_CHANNEL_2, 0);
//LED_B fading
Serial.println("LED_B is fading");
Serial.print(".");
ledcAnalogWrite(LEDC_CHANNEL_3, brightness);
delay(30);
Serial.println();
ledcAnalogWrite(LEDC_CHANNEL_3, 0);
Serial.println("--Over--");
***Function:ADC(channel_1) Test ***
Serial.println();
Serial.println("ADC test!!!");
Serial.println();
for (adTestFreq = 0; adTestFreq < bout; adTestFreq++)
// turn the LED on (HIGH is the voltage level)
AD_Value0 = analogRead(AD10);
AD_Value3 = analogRead(AD13);
AD_Value4 = analogRead(AD14);
AD_Value5 = analogRead(AD15);
AD_Value6 = analogRead(AD16);
AD_Value7 = analogRead(AD17);
//AD10-Pin:IO36
Serial.print("AD10:");
Serial.print(AD_Value0);
Serial.println();
//AD13-Pin:IO39
Serial.print("AD13:");
Serial.print(AD_Value3);
Serial.println();
//AD14-Pin:IO32
Serial.print("AD14:");
Serial.print(AD_Value4);
Serial.println();
//AD15-Pin:IO33
Serial.print("AD15:");
Serial.print(AD_Value5);
Serial.println();
//AD16-Pin:IO34
Serial.print("AD16:");
Serial.print(AD_Value6);
Serial.println();
//AD17-Pin:IO35
Serial.print("AD17:");
Serial.print(AD_Value7);
Serial.println();
Serial.println();
Serial.println();
delay(1000);
***Function:Wi-Fi Test ***
Serial.println();
Serial.println("Wi-Fi test!!!");
Serial.println();
// //Wi-Fi connect
// Serial.print("Connecting to ");
// Serial.println(ssid);
// WiFi.begin(ssid, password);
// while (WiFi.status() != WL_CONNECTED)
// delay(500);
// Serial.print(".");
// Serial.println("WiFi connected");
// Serial.println("IP address: ");
// Serial.println(WiFi.localIP());
// Serial.println("Setup done");
// Serial.println("");
// WiFi.disconnect();
for (wifiTestFreq = 0; wifiTestFreq < 1; wifiTestFreq++)
Serial.println("scan start");
// WiFi.scanNetworks will return the number of networks found
int n = WiFi.scanNetworks();
Serial.println("scan done");
if (n == 0)
Serial.println("no networks found");
else
Serial.print(n);
Serial.println(" networks found");
for (int j = 0; j < n; ++j)
// Print SSID and RSSI for each network found
Serial.print(j + 1);
Serial.print(": ");
Serial.print(WiFi.SSID(j));
Serial.print(" (");
Serial.print(WiFi.RSSI(j));
Serial.print(")");
Serial.println((WiFi.encryptionType(j) == WIFI_AUTH_OPEN) ? " " : "*");
delay(10);
Serial.println("");
// Wait a bit before scanning again
delay(2000);
***Function:Buzzer Test ***
Serial.println();
Serial.println("Buzzer Test!!!");
Serial.println();
for (buzzerTestFreq = 0; buzzerTestFreq < bout; buzzerTestFreq++)
Serial.print(".");
ledcAnalogWrite(LEDC_CHANNEL_0, brightness);
delay(30);
Serial.println();
ledcAnalogWrite(LEDC_CHANNEL_0, 0);
Serial.println();
Serial.println("---------Test Over !!!---------");
主要测试功能介绍:
- RGB三色LED循环渐变控制测试。
- 6条ADC_channel1的AD采集测试。
- WiFi扫描测试。
- 蜂鸣器渐变控制测试。
测试状态查看:
串口连接板子与PC,串口配置:115200-8-N-1
