BPI:bit 的正面板采用的是1600w色真色彩的LED-WS2812,那么也就是说我们后面可以玩很多各种花样了。这个灯具体怎么玩,我后面会整理一下和大家分享,我也只是会用基本的函数
这次先来玩一个简单点的。通过按键来控制LED的亮与灭,
代码如下
#include <Arduino.h>
#include <NeoPixelBus.h>#define LEDC_CHANNEL_0 0 #define LEDC_TIMER_13_BIT 13 #define LEDC_BASE_FREQ 4500 const uint16_t PixelCount = 25; const uint8_t PixelPin = 4; #define colorSaturation 128 #define delay_ms 500 NeoPixelBus<NeoGrbFeature, Neo800KbpsMethod> strip(PixelCount, PixelPin); RgbColor red(colorSaturation, 0, 0); RgbColor green(0, colorSaturation, 0); RgbColor blue(0, 0, colorSaturation); RgbColor white(colorSaturation); RgbColor black(0); RgbColor num1(0.8 * colorSaturation, 0, 0.2 * colorSaturation); RgbColor num2(0.5 * colorSaturation, 0, 0.5 * colorSaturation); RgbColor num3(0.25 * colorSaturation, 0, 0.75 * colorSaturation); HslColor hslRed(red); HslColor hslGreen(green); HslColor hslBlue(blue); HslColor hslWhite(white); HslColor hslBlack(black); #define ledPower 2 #define BottomA 35 #define BottomB 27 void ledcAnalogWrite(uint8_t channel, uint32_t value) { // calculate duty, 8191 from 2 ^ 13 - 1 (2 ^ LEDC_TIMER_13_BIT - 1) //value_MAX = 255 uint32_t duty = (8191 / 255) * value; // write duty to LEDC ledcWrite(channel, duty); } void setup() { Serial.begin(115200); //Serial Port Config 115200-8-N-1 while (!Serial) ; // wait for serial attach Serial.println(); Serial.println("Initializing..."); Serial.flush(); // this resets all the neopixels to an off state strip.Begin(); strip.Show(); pinMode(ledPower,OUTPUT); pinMode(BottomA, INPUT); pinMode(BottomB, INPUT); digitalWrite(ledPower, HIGH); // strip.SetPixelColor(10, blue); // strip.SetPixelColor(11, blue); // strip.SetPixelColor(12, blue); // strip.SetPixelColor(13, blue); // strip.SetPixelColor(14, red); // strip.Show(); // delay(1000); // int i; // for (i = 0; i <= PixelCount - 1; i++) // { // strip.SetPixelColor(i, black); // strip.Show(); // } } void loop() { if (digitalRead(BottomA) == LOW) { delay(10); if (digitalRead(BottomA) == LOW) { strip.SetPixelColor(16, num1); strip.SetPixelColor( 7, num2); strip.SetPixelColor(18, num3); strip.Show(); } else { int i; Serial.println("Turn Off"); for (i = 0; i <= PixelCount - 1; i++) { strip.SetPixelColor(i, hslBlack); strip.Show(); } } } }
程序的过程很简单,按下有三个灯亮,松开就灭。github地址
