BPI-R2 Ubuntu with Linux kernel 4.14 source code release V1.0 2018-4-28
- Summary for this release;
This release is for BPI-R2 Ubuntu OS with linux kernel 4.14 source code,you could download source code from this link:
- What’s new:
- Wifi client / AP mode support
- 4G module support
- Known limitations:
- HDMI not working
- BT/BLE not working
FAQ:
1) How to enable 4G module on R2 with kernel 4.14?
You could see relevant info from here: How to use BPI-4G LTE module with BPI-R2 - Banana Pi BPI-R2/BPI-R64/BPI-R3 - banana pi single board computer open source project official forum BPI team
2)How to enable wifi client?
wmt_loader (ignore errors)
stp_uart_launcher -p /etc/firmware &
ip link set wlan0 up
iw dev wlan0 scan | grep SSID
vim /etc/wpasupplicant/wpa_supplicant.conf
network={ ssid=“ssid” psk=“password” priority=1}
wpa_supplicant -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
dhclient wlan0
3)How to enable AP mode?
echo A >/dev/wmtWifi
create your hostapd.conf: "vim /etc/hostapd/hostapd.conf "
hostapd.conf (236 字节)
According to your network interface(can search internet) to config ap0:
my network interface which can search internet is wan, and ip is 192.168.30.102, so I config ap0 as follows:
“ifconfig ap0 192.168.30.188 netmask 255.255.255.0”
Run hostapd : “hostapd -d /etc/hostapd/hostapd.conf”
Config dhcp file : “vim /etc/dhcp/dhcpd.conf”
subnet 192.168.30.0 netmask 255.255.255.0 {
range 192.168.30.2 192.168.30.250;
option domain-name-servers 8.8.8.8;
option routers 192.168.30.1;
Config dhcp of ap0, then the devices which connect ap0 could get IP: "dhcpd ap0 -pf /var/run/dhcpd.pid "
And a bridge
brctl addbr br0
brctl addif br0 ap0
brctl addif br wan
Config br0 : “ifconfig br0 192.168.30.180 netmask 255.255.255.0”
Add br0 gw as : “route add -net default netmask 255.255.255.0 gw 192.168.30.1 dev br0”
Thanks for every developer who contributes to this project, especially :
@garywang @frank-w.
