banana pi 硬件升级声明:eMMC 5.0 升级到eMMC 5.1
1 如何确定您购买的板是新的eMMC ,还是旧的eMMC?
检查你的eMMC 类型ID:
B031 是旧的 EMMC 5.0
B041 是新的 EMMC5.1
这里用BPI-M3做说明
2.为什么我们要升级eMMC?
新的 Emmc5.1 读写速度更快
旧的eMMC 5.0 将会停产,供货困难。
3.If you have board with new Emmc, you use command ‘fdisk -l’ can’t recognise Emmc, how to update your image to support the new Emmc?
Here I use BPI-M3 as an example:
execute “bpi-tools”, to update your bpi tools;
execute “bpi-update -c bpi-m3.conf”, to download new driver to update your image
execute “file *.tgz”, to check download files’ type is compressed data
execute “bpi-bootsel”, you will see the bootloader path, “/usr/lib/u-boot/bananapi/bpi-m3/BPI_M3_720P.img.gz”
execute “bpi-bootsel /usr/lib/u-boot/bananapi/bpi-m3/BPI_M3_720P.img.gz”, to update your bootloader
reboot
