I try to install opencv library “ibcv-dev” and when I use it to turn on my ov5640hdf camera,it shows following information,I don’t know how to solve this problem,couble anybody help me?
I heard that from this link (【小撸】M2 安装/运行/编译OpenCV程序)
opencv code
#include <opencv2/highgui/highgui.hpp>
#include <opencv2/core/core.hpp>
#include <iostream>
using namespace cv;
using namespace std;
int main()
VideoCapture cap(0);//打开摄像头
cap.set(CV_CAP_PROP_FRAME_WIDTH,640);
cap.set(CV_CAP_PROP_FRAME_HEIGHT,480);
if(!cap.isOpened()){
cout << "open camera failed. " << endl;
return -1;
Mat frame;
while(1){
cap>>frame;//读取当前帧
// imshow("XiaoLu OpenCV CAM", frame);
if(waitKey(20) >=0) break;
return 0;
console
root@bpi-iot-ros-ai:/home/pi/work/prj# ./opencv_cam
libv4l2: error setting pixformat: Operation not permitted
HIGHGUI ERROR: libv4l unable to ioctl S_FMT
Floating point exception
