【转】Banana Pi M2 running openSUSE Tumbleweed
Following up from my earlier post about openSUSE LTSP on Banana Pi, Nora Lee from the manufacturer of the board got in touch with me and sent me couple of their new boards- Banana Pi M2, runs on A31s quad-core CPU and has 1G RAM, powerful enough to run openSUSE Tumbleweed with Xfce Desktop.
Here is how you can get openSUSE running on Banana Pi M2.
  • Download the image
  • Extract the archive to get openSUSE-Tumbleweed-Bpi-M2-Xfce.img
  • Dump openSUSE-Tumbleweed-Bpi-M2-Xfce.img on to a SD card
    (dd if=/path/to/openSUSE-Tumbleweed-Bpi-M2-Xfce.img of=/dev/sdX bs=4M; sync #replace /dev/sdX with your actual SD card device)
  • In case you have a bigger SD card, use yast2 disk(partitioner) to “expand” the second partition. You can use yast’s package manager to install more software. The default password for root is linux, you may want to change that first thing after booting.
I am unable to get sound on this hardware, probably their kernel is missing sound related modules, if you figure out how to get sound working drop me a line so I can include it in next release.Everything else(wifi, hdmi out, USB ports etc) works well enough.
赞一个!
树莓派可以吗?
[quote=“suoma”, post: 3, topic: 926]
suoma 发表于 2015-12-3 21:34
树莓派可以吗?
应该不行额,,要不你试试
